pappawheely
Autonomous4X4
Starting a new project built from parts I have lying around. I was going to do a powertrain swap and SAS on my 1985 Trooper. I started looking at all the fabrication work needed and what I wanted to upgrade. I came to the conclusion that the only thing I really liked about the Trooper was the body; the way it looks. That's when everything went so wrong. I just happen to have a chassis and drivetrain for a 1979 Chevy Blazer sitting around. Basically all the mechanicals would be sorted out and it has some nice parts to go along. Realistically (or unrealistically) all I would need to do is mate the body to the chassis, figure out the steering and wire it from scratch. No sense using an old wiring harness. The Blazer's wheel base is around 2 inches longer, but if I want to run big tires I would need to stretch it in front anyways. Just think... a 1985 Isuzu Trooper with V8 power, 3/4 ton drivetrain and 37 inch tires. I have a mildly built 350, turbo 400 and 205 transfer case. Front Dana 44 and rear 14 bolt. The 14 bolt was swapped into the Blazer. One big issue I have been dealing with on this project already is getting the rear 6 bolt, hubs to work. I wanted to run Toyota 4 runner wheels but they just aren't going to work. The center bore is too small. I had to pick up some Methods with a 108 center bore and those barely clear the hub and axle bolts. The person who designed the rear hubs did not think things through as it's been a struggle to make this work with 6 bolt wheels. Wish me luck the rest of the way. It's going to be my winter project.
