The Trooper/Blazer I call Blooper.
I ordered a TORQ locker for the front. I did research on all the "lunchbox" lockers. The TORQ wasn't the cheapest, but I think it's the best design. It doesn't use pins. Instead the two halves of the center section lock together. I thought it was also pretty cool that one of the owners of the company replied to my inquiries on social media with answers to my questions on a Monday evening. If I'm going to spend my money, I like to give it to good people!
Here I go farther into the black hole, but I can't help myself. I get sucked into "how do I make things better." I have to pull the carrier out now, but my inner axle tube seal was leaking on one side. It's silly to tear everything down and not change those I guess. That's what I'm using to justify this.
Back when I was driving this as a Blazer, I was going up a loose, rutted out hill that was steep. I kept getting stalled out because one front tire was spinning. Even with the posi in the rear. A guy waiting behind me asked if I had a rear locker, I said yes. He said put it in 2WD and send it. I never forget that because I learned a lot about 4WD that day. I'm already concerned about the capabilities this truck will have. The gearing is all wrong. Turbo 400, 205 and 3.73 gears on 37's. My crawl ratio is a pathetic 18 to 1. I really want a doubler, but the cost is just way too high. Maybe I should start a gofundme or something. Help a starving artist get through tough trails! A photo of me looking pathetic will be easy! :unsure:
Some people may think I'm ruining a good Trooper, but that's not the case. This truck has had a hard life apparently. I pulled up more of the floor covering and sound deadening. WOW! In a few years this truck would have rusted from the inside out. The underside of the truck is spotless. The inside is covered in cancer. The factory sound deadening is a bad design. It's jute against the steel floor with thick rubberized coating on top. The jute holds moisture against the steel. No bueno. I hope the rear of the truck is not in the same shape.
The cargo area in the back of the truck had more widespread rust, but it was less severe. It was hot inside doing all that grinding.
Here is my weapon of choice. If you are going to use a wire wheel, be sure to get the ones that are twisted or braided. The wheels with straight wires coming out jettison the wires into your body and they are useless in a matter of minutes. The braided ones last much longer and you are able to put some pressure into them. Make sure you have eye protection!!! It's also smart to wear a respirator because you have no idea what's in the dust you will be breathing.
I am hoping that I can weld up some of the smaller perforations with my mig welder. When I was doing restoration, we used acetylene and welding rod. You had so much control of the heat with gas. Mig is not as precise. The last thing I want is a sea urchin of wire sticking out under the truck.
Next I'll treat the metal with something. I've used a bunch of POR15 in the past, but that stuff's very expensive now. I have some Krud Buster stuff sitting on a shelf. I'll try that first. I still need to pull the front seats out and do the cab floor. The front corners of the wheel wells are going to need patch panels. I was thinking while I was at it, I could put in a dead pedal. I'll be running an auto trans so I only have 2 pedals.
Use any cheap rust converter that dries to a paintable finish, then prime and seal. POR15 is an encapsulator not a converter anyway. I try not to encapsulate rust ever anyway.
More grinding and cleaning today. I got a lot done, but I still need to pull the door panels and side panels then scrub the interior. The good news is I can just spray everything down with the hose. All the electronics have been removed. I'm going to have to take a couple days off. The slice I put in the palm of my hand got infected. I'm going to have to let it dry out and heal a little bit. Even with gloves on it got constantly irritated and I didn't take very good care of it. Having a high pain tolerance is not always a good thing.
I have everything I need to put the front diff together. New axle tube seals. The installation tool. The torq locker I ordered. New axle shafts and u-joints. New hub seals. Once I get that all done it will be back on 4 wheels. I also have the pitman arm and steering links out for fab and welding. One issue I need to address is the badly dented rocker on the passenger side. I am going to weld some 2x6 rectangular tubing to the rocker. It will act as a slider and also I was going to use it to mount the body to the chassis. I've had a spot weld gun for years and never used it. Now is my chance.
I'm learning a lot watching this scratch build from Mike Essa. Such a cool truck. I just wish I had a tenth of the skill Essa has. If you watch the other videos you will also see Brandon who I used to work with along with his brother Justin. Good people. Check it out. I'm going to be stealing Mike's ideas big time! :ROFLMAO:
I started looking at the firewall. I'm trying to focus on simplicity on this build. The Trooper is helping me because it's a pretty simple truck. I'm running the same size caliper on every corner. Therefore, I'm running the old school "corvette" master cylinder with no booster and a loooong pedal. This should give me good brakes, but without having to worry about vacuum. I'll plate over the firewall and make new holes, but surprisingly, the master will mount just about where the trooper master cylinder mounted. I'm waiting for the corvette pushrod I ordered. Not sure what's up with USPS, but everything they ship is late and the tracking is lacking. :D
You can see the original mounting holes for the Trooper stuff. I will be re-using the Trooper gas pedal because it is a cable. It will work with the Holley carb I'm getting built over at C&J engineering. John is going to be doing the off road tricks to it so it will work in the bumps.
I'm installing a GM tilt column from the Blazer donor. Since it was a manual truck the column is clean with no shift linkage. I'll be running a cable shifter on the Turbo 400 transmission mounted on a center console. The column is going to fit in nearly the same location as the Trooper 😍. I need to cut the bracket off the end of the column where it used to mount to the firewall and make a new bracket for it. Then adapt the upper mount to the stock Trooper part. Not a big issue. So happy it's going to work. I still have the keys to this column.
I did some measuring and the steering linkage clears the headers with no issue, I was surprised. The only down side I've encountered is all the holes all over the firewall that I won't need. That huge hole on the right was for the wiring harness. I'm not doing that. I'm planning on mounting the batteries and all the fuses and electrical inside the cab; hidden in the dash and center console. I'm not going to have inner fenders to mount all that junk on anyways.
Back on the front axle today. Pulled the carrier out after having to consult YouTube university. At first it wouldn't budge. Then I watched a video showing how to put a prybar in the carrier housing and turn to driveshaft. Came right out. Just make sure you leave the bearing caps bolted loosely so the carrier doesn't fly out. The paint marks are so the bearing caps go back on exactly how they were.
Next I removed the inner axle seals. What a rusty mess. I tried using a long pipe to knock them out. I couldn't get a decent hit on the slight lip of the seal. Then I used a 36mm socket with the same pipe. Came out with a ton of debris. What mess. I'll clean it up and install the TORQ locker and new seals tomorrow.
Say goodbye little friend. My little friend is the firewall. I got the front axle all together and dropped it on the tires. It allowed me to take some measurements. Looks like the engine is going to get into the firewall a few inches. That's not a big deal except the width of the motor. I may need to ditch the blazer steering column. The Ford design only has the shaft going through the firewall. The column doesn't go to the firewall. I have ford parts trucks laying around. Next issue will be the gas pedal. Time to do some figuring. As soon as I get my steering components from the fab shop I can maneuver the blazer chassis. The priority right now is getting the rocker panel on the trooper pulled out. Then I can pull the Trooper body off the frame and set it on the chevy chassis. Then the cutting can begin. The dash is going to be fabricated anyways, so making a custom firewall and tunnel was already planned. I think having a removable section on the firewall (like a van) will be a good thing.
When I did my engine swap the 80/20 rule really applied.
80% of the project takes 20% off the effort.
All the little piddly crap that isn't on a guy's radar when you start is the other 20% that takes 80% of the effort.
Like I said, the front end is all together. I picked up the steering linkage at the fab shop. They still need to build the pitman arm. They are building some amazing vehicles there, so my stuff is just fill in work. I was going to paint the linkage with STEEL-IT, but it looks so cool, maybe I'll hit it with some clear. :love:
Chromoly axles
Warn hubs.
New calipers, lines, high steer arms, etc.
The trooper chassis has left the chat!
I used the good old camper jacks to lift the body up. I set it down on some steel saw horses I fabricated, then rolled the old chassis out and the blazer chassis in. The camper jacks were too narrow to clear the tires. That's why I needed the saw horses. Then I took the body off of them and set it on the blazer chassis.
It's sitting a little high in the front because it's hitting the frame where it kicks up in the front. That is right where all the rust holes are so it's a win, win. I need to cut that out anyways. The firewall needs to go too in order to clear the motor.
I could not be any happier about how the body sits. There is a body Xmember that almost lines up perfectly with the two blazer body mounts in the rear that I didn't remove. The gas tank sender has clearance. The springs have clearance in the back and the front shocks also have room. It's going to sit right down on the frame like it was made for it. SO RELIEVED!
She does have quite the booty now. It's actually a good thing. I'm going to mount a large swing out tire carrier in the rear. I can set it right on the frame rail. It will have a 37 inch spare on one side and two jerry cans on the other. The frame will be under those things so it won't look out of place.
The trailer hitch is a bit of a boat anchor. I looked at it and decided I can cut the cross tube out of it and turn it upside down. That will give me a bunch of ground clearance and tuck everything up tight. Then I can cut the frame rails that are hanging out off too. I was underneath and noticed there is a big open space between where the blazer chassis kicks up in the rear and where the front of the raised rear floor is in the trooper. I can cut it out, sink in some boxes and mount my batteries down at frame level. Another win, win! With the batteries in the rear, I can mount a connector inside the trooper gas door to plug in jumper cables. How cool is that? The blazer tank in the rear will have to be filled through the quarter panel, but that's an easy mod.
So proud of myself. A few scratches but still have all my fingers, no slices and no puncture wounds. I also got rid of the rust, sound deadening, bumps, bulges and the swiss cheese firewall. Plenty of room for activities now. I took a lot out, but now I can put it back simple and strong. It turns out my sawzall loves sushi! Oh, I did nick the frame in one spot. I'll have to weld it up, no big deal.
I cut the floor out right in front of the seat mounts.
You can see I have nice clearance around the transfer case mount. I can use the lever twin sticks instead of the more expensive cable shifter.
Tomorrow I'll put the body back on the saw horses, roll the chassis out and install the driveline and engine. Then I can start designing the new floor, dash and center console.
During my daily visit to FB marketplace, I saw this toyota camper on a jeep cherokee chassis. The struggle is real when you put a Japanese truck on a V8, full size chassis. :oops:
Put the motor in to check clearances. I still need some room on the firewall. Width is fine. ;) Need some more clearance around the distributer. Good thing I am running a hat and snorkel to the carb. A decent sized air filter on top of the carb won't fit.
I might be able to run the entire front clip and fenders. That would be nice. I think 37's will fit fine, front and rear.
2eleven
