GXV Mercedes Unimog U500 Worldwide Expedition Vehicle Camper Truck - Exceptional Oportunity. (European/USA) - FOR SALE for serious health reasons
Hello.
Early 2024 I was selling this truck. Health reasons almost did not allow me to use it, unfortunatly, for years.
The same serious reasons have taken me to hospital for many monthes since early 2024 and could not manage anything about the sale neither contacts from anybody. I'm now able for a while to manage the issue again. hopefully time enough for selling the rig. Adds have not been reactivated yet. I will in the next couple of days. One of the mains editors of Overland Journal knows about this issue.
The truck as almost never neen used I drove only 5000 km in roads in europe. It is 25.000 km in total (most of them done by GXV before i bought. And since 2024 it is located in a protected place taking care of it.
Meanwhile, hereafter are the original threads from early 2024 if you are interested.
The truck is EU registered in this moment. But was already on USA plates before that till 2011. It was imported to USA from Freightliner /Mercedes and expedition vehicle was built in Missouri by Global Expedition Vehclies. So it should not have to pay reimport taxes cause it already did, and also the GXV vehicle was manufactured in USA. I am not expert on taxes neither USA or othe countries regulations, but in the old therads, USA /Canadian peolple will find some infos from people that know much more than me about this issue.
The vehicle is in this moment in Europe. If you are not thinking about seing the truck personnaly there before buying, do not loose your/our time. It is a must see truck. I can supply on personal basis a lot of pictures, video, infos comments and docs. But before buying it, YOU MUST SEE IN PERSON. And then you should have to take a plane ticket if seriuosly interested. Here is a picture of the truck in August 2010 when I visit it and bought it in Missouri. Since then, almost not used at all (2 weeks in portugal and 2 months in a camping), but a huge amount of modifications and improvements have been done, specialy regarding is already impressive offroad capabilities, security issues and motorcycle carrier issues (ALWAYS THINKING AND PREPARING THE VEHICLE FOR THE TRIP I HAVE NEVER BEEN ABLE TO DO). Many relevant improvements have been done in order to allow a realistic capability of overlanding ALONE. If someone has been dealing with a truck this weight, size and complexity, you probably know how much critical is this issue when you are a single person alone dealing with any issue on the road, even as simple has changing a spare wheel/tire. All has been prepared to allow one single person to manage those issues alone, and it si not easy.
Original 2024 therads:
Here attached the docs with detailed description of the vehicle as it is today
  • Unimog U500 USA 2005-techdata.pdf
  • Unimog U500 Global Expedition Vehicle (World Camper Truck) Mercedes Benz TRUCK Description EN ...pdf
  • Unimog U500 Global Expedition Vehicle (World Camper Truck) Mercedes Benz HOUSE Description EN ...pdf
kcshoots
Hi there. Sorry to hear about your health issues and lack of being able to use this fine camper. Some questions to help answer what I don't see in the info sheets.
It looks like a rear lowering motorcycle carrier was installed by GXV and since removed. Is that the case?
And is the total length stated in the document including it and/or the rear under-crash protection bar, or to just the rear of the rear wall of the cabin?
Also, what is the total height to top of air conditioner from ground?
Also looks like the spare tire was relocated from a slot under the rear storage compartment to the front bumper around the front winch, is that because the rear under-crash protection bar was shortened or another reason?
Also, the info sheet indicates that this has the factory central tire air inflation system, but not exactly clear from that info or the photos--can you confirm?
Thank you.
Channelmarker
T3 - Thing Three
So, what is the offered price and are you up for negotiations? Also, what 's the horsepower of the engine, and I also would like to see a specs sheet if possible.
Thank you.
I answer in your text in CAPS
It looks like a rear lowering motorcycle carrier was installed by GXV and since removed. Is that the case? IT IS THE OPPOSITE. THE PICTURES WITH COORED STCIKERS AND WITHOUT MOTORBIKE RACK ARE WHEN I BOUGH FROM GXV IN MISSOURI. THERE IS A SPECIAL RACK SPECIALLY DEDIGNED AND MANUFACTURED FOR
And is the total length stated in the document including it and/or the rear under-crash protection bar, or to just the rear of the rear wall of the cabin? THE PROTECIOON BAR IS A NEED IN EUROPE. THE WHOLE THING HAS BEEN REGULAR HOMOLOGATED AND REGISTERED.
Also, what is the total height to top of air conditioner from ground? FEW CM OVER 4 METERS
Also looks like the spare tire was relocated from a slot under the rear storage compartment to the front bumper around the front winch, is that because the rear under-crash protection bar was shortened or another reason? AGAIN IT IS THE OPPOSITE. THE PICTURES YOU LOOK AT ARE AS I SAID THE ORIGNAL TRACK FROM GXV THE FRONT WHEEL HAD NO SENSE THERE. AND COULD NOT HAVE WINCH WITH IT
Also, the info sheet indicates that this has the factory central tire air inflation system, but not exactly clear from that info or the photos--can you confirm? TES I CONFIRM. PERMANENT TIRE PRESSURE MONITORING AND INFLATION DEFLATION SYSTEM PER AXLE OR 4 WHEELS TOGETHER
Thank you. YOU ARE WELCOME
CONTACT ME BY EMAIL AND WILL SUPPLY YOU ALL THE NEEDED INFO. THERE ARE AND WILL BE TO MUCH QUESTIONS TO BE ANSSWERED OINT BY POINT. IT IS BETTER TO SEND THE PROPER COMPLETE INFO.
IS IT OK FOR YOU ?
THANKS
Thank you.
THIS PICTURES ARE THE ORIGINAL GXV VEHCILE THAT HAS BEEN SIGNIFICANTLY IMPROVED02082010026.jpg02082010031.jpg
YOU HAVE THE PRICE IN THE THEADS. 295.000 € REGARDING HE SPECS I ALREADY PROPOSED YOU THE WAY TO SEND DETAILED INFO.
I DO NOT KNOW IF IT IS POSSIBLE TO POST HERE AN EMIL ADRESS
Hello to the people that already posted quesions. I first of all thank you very much
For all of them and potential future interested please have a look to all the infos and docs and pictures and videos already posted in the various threads 2024 and this last one. i am almost sure that 99,9 % of the questions are answered already there.
thank you
H
thank you
H
I will obviously could answer much more detailed questions that could be not answered there, if needed. And send additional info on personal basis for really interested persons, But this truck as to many things to answer to each detailed point casa by case
thanks
