1993 HiAce Firetruck Build Thread
Fenderfour
I've been trying to get some work done during the relatively dry Seattle winter we are having. I managed to finish insulating the lower camper with 1.5" XPS foam. I found the best way to cut it is with a sharp snap-blade knife and make a few passes. The insulation saws and even the serrated knife make too much 'chaff'. I wanted to set up a large frame hotwire, but never got around to it.
I found some great garage tiles to use as flooring at Lowes. They are ~.2" thick x 20" square vinyl and are fairly easy to cut. They were at the local Lowes but I can't find them online. I know lots of folks go with Lonseal coins, and I get it, and it's really expensive. These tiles were less per square foot, thicker, and easy to install. The new flooring also filled in the exposed height of the seat tracks I installed to allow for a variable interior. It's nice having a 'real' floor instead of tromping on the painted Coosa or the towels I had down to catch mud.
I also found a solid product for wall covering. Cheap indoor/outdoor rugs. These are particularly well suited to my build since the cabin is 6'x6'. I looked at automotive carpet, speaker box carpet, and few other things like that. Most of them didn't have a bonded back so they could form a bit better. I've used rugs similar to the link above for camping and they are pretty good. Lightweight, durable, and I don't have to buy a huge roll. I got the lower bed area covered in carpet and will get the other walls covered when we have another good weather day. I want to get the carpet behind the window flanges, so they need to come out one more time. The carpet is installed with carpet tape, and the bonded back made that easy. I also have a series of snaps installed on the upper edge to eventualy create insulated curtains for the pop-up, but for now, they will help hold the wall covering up.
I've followed the discussions here and elsewhere on interior covering. Seems counter-productive to put 1/2" or 3/4" T&G wood on the inside of a camper. It takes up volume, is heavy, needs additional finishing, etc... I was interested in some of the coroplast ideas, but i wanted something to cut down on the harsh soundscape a semi-rigid material would create. I could have covered the coroplast with this carpet, but why? Sometimes our ideas of how to build something stem from familiar systems, like our homes. Wood paneling makes sense in a home. Does it make sense in a camper? Putting a rigid sheet of 'something' over the structure is also a holdover from our homes, but is it necessary?
I've been aware of moisture management for a fair bit of my build. There are paths for water to exit all walls, the floor, etc... Nothing but the exterior roof is fully sealed. All walls and the floor have paths facing aft to drain. The interior wall covering is permeable to allow dray air to get into the insulated area when the heater is running.
I'll keep building small, light, and simple. Looking for a reliable easy to maintain toy to enjoy the world and nature. Not a tech-laden hideaway to watch the game while I park under the trees.
Fenderfour
more work this weekend. I added a bunch of nutserts on the interior to mount /waves hands/ stuff. I don't really know what the interior will be, so I wanted to add nutserts in locations where I might want to add something. I had been using a 13" nutsert/rivnut tool and it works well, providing a lot of pulling force, but it was also tricky to operate, required two hands, would strip the insert if it wasn't adjusted correctly, didn't provide an 'feel' when using, etc... So I switched to a smaller tool and it's much better. I'm guessing there is a size of nutsert that requires the larger tool, but I'm getting up to 6mm and the small tool is working great.
Here's the large tool I see a lot of youtubers and other DIY folks recommending. There are lots of manufacturers, they all seem about the same.
Here's the tool I switched to. Easier to use for small inserts, more clearance for tight areas, etc... I'm also installing aluminum nutserts into aluminum and I can feel when it's compressed. The larger tool had to be carefully adjusted or I would pull the threads out of the insert, then have to drill i tout, etc...
Also added some carpet padding on the floor in the form of the cheap 1/2" Harbor Freight fatigue mats. At about $0.60/sq ft. It's hard to beat.
Fenderfour
Dry weather in Seattle meant time to work on the truck.
There is a lap joint between the ACM and the diamond plate corners on the roof of my camper. It's got a reasonable amount of 5200 marine adhesive and sealant up there, but I wanted another layer. On friday I scrubbed the roof and saturday I applied a line of RV roof repair tape along the seam. You can see it in the photos below. It's a belt-and-suspenders thing, but I feel better about it.
I also installed the rigid 200W solar panel that came as part of the ACOPower system i purchased on indiegogo. The panel is pretty standard fare. I thought I was going to need to build racks and screw it to the roof, but FarOutRide shows VHB on the Z-clips for mounting, and it's been plenty strong for them. I wanted a little more area, so I created 48" brackets from 1.5" angle aluminum. Those are VHB'd and sealed to the roof (like FarOutRide does for theirs). I drilled into the side of the solar panel and added 5mm Nutserts in 3 places on both sides of the panel. There are screws that go from the brackets into the solar panels to hold it on. Super easy to mount/dismount, only added maybe a pound of weight for mounts.
Bottom of the panel, brackets attached, red is release film for the VHB
Backside look at the aluminum nutsert in the solar panel
front side of the panel showing the bracket
lots of roof, a little bit of solar. You can also see the RV roof tape along the edges.
I put the solar on the front side of the roof because it was more difficult to close the front side of the pop-up. This extra weight makes it easier now. The panel isn't hooked up to anything. I do have an all-in-one mppt, inverter, and ac/dc charge unit, and a 230Ah LifePo battery, but I'm not sure where I'm going to mount it in the camper, so that's on hold for now.
Last week I took my truck out for camping and it was a bit bouncy. I hypothesized it was due to increased spring rate in the front (i installed heavy duty torsion bars from Sway-Away) pushing the load into the stock leaf springs in the rear. I think the HD torsion bars have 60% heavier springs?
I usually look at possible causes of an issue and then look at possible fixes and start with the cheapest/easiest to start. RRuf suggested some new shocks might help, but that's a trial and error to find the right fit, and expensive. I thought maybe balancing the spring rate forward and aft would work. I looked in to custom spring packs, and like the shocks, there is a lot of trial and error and a lot of $$$. I did some measuring on my leaf stack and realized it was very similar to the old Toyota Pickup (pre-tacoma, pre-T100). Lots of companies have add-a-leaf kits for these trucks, and I found one that was on sale for $60.
I spent four hours, a can of PBlaster, a new set of 1/2 drive impact sockets, and one broken flex head ratchet to get the new leafs installed on sunday. I took the truck for a spin, and it was great. The truck isn't plush by any means, but the bounce was gone. It felt more like the original truck.
allochris
How's the turbo project going? My oil pan is unbolted for installation of the turbo drain tube adapter, but currently stuck above the lower crossmember. Looks like I need to unbolt & lower the whole lower half of the front suspension cradle about 4" to allow the oil pan free. Do you have a similar setup as my 02' Dyna?
Fenderfour
There's an installation video from HD Automotive. It's not all the same stuff as our trucks, but it's a good stating point. They do show needing to drop the diff to get the oil pan out.
I've been doing a lot of thinking about the installation, looking at the build thread at iH8Mud, and a few other sources.
I didn't like how the guy on IH8Mud crammed a cone filter on the end of the turbo. I want a better solution. I've been trying to find a way to make a reasonable air intake work on the right side, and I'm coming up with nothing. I also don't understand why he's using such large tubing. 3" is overkill and makes the packaging more difficult than it needs to be.
My current plan:
Route intake air from the existing airbox, sending tubing forward to the frame member and up through a gap between the radiator and frame then in to the turbo inlet.
Route pressurized air to the engine by going in front of the engine, between the radiator fan and the belt covers. This will probably be oval tubing. The pressurized air can then drop on to the existing intake manifold.
The IH8Mud thread mentions modification of the shift linkage to get the 3" dump pipe on the turbo. I'd rather not mess with it, so I got a 2.5" pipe and flange to make my own dump pipe. It's considerably smaller than the 3".
I also need to modify my current exhaust manifold (I think...) The IH8Mud thread shows the turbo in the middle position, between cylinders 2 & 3. Mine has the turbo between 1&2.
My first-draft doesn't have an inter-cooler. If I add one, it will be a side-mount with fan installed near my battery.
In theory there will be a bit of lag with all the piping. I don't think it's a big issue since I'm not racing anyone in the truck, and the whole system just get pressurized and the engine breathes from the supply. There's no blow off valve to reset the pressurization process on these old diesels.
Where I'm at:
I've lined up someone who can help with the tig welding. I've never learned and don't want my first welds to be oil return or exhaust parts under my butt.
I'm waiting for dryer weather in Seattle to get started on the installation since I'm working in my driveway.
allochris
My current plan:
Where I'm at:
That's good stuff. I have to look up how different layout the engine components of our Dynas are. I also have a draft plan of where everything goes, but I dont want to hijack your post. Once I get some photos of it all I'll post it onto my existing Allochris camper thread, that way we can compared our approaches as we build it all out. I think we are both about on the same pace on the turbo build, which is very slowly as I'm slowly collecting all the bits & pieces parts, and also crawling over wet thawing dirt ground...a very weather & time dependent project!
Fenderfour
I had a bit of ok-ish weather and some coosa board left over from the structural camper build. I decided to use it to build a galley cabinet.
If you don't already know, Coosa is a composite consisting of polyurethane foam with a front and back layer of non-oriented fiberglass to provide rigidity. It' great stuff, if expensive. A sheet of 3/4" is about $400. It's about half the weight of wood and has a similar structural strength.
I had a few fancy ideas in my head for the cabinet, but decided to go with classic cabinet construction. It's 20" deep, 40" wide, and 32" tall. I would have liked a taller counter, but I didn't want it covering up the windows in the camper.
I also had a slab of acacia at the shop, so I cut it for the counter. I really didn't want to have a slab top, mostly because it's heavy and many builders add them to give that 'luxury' feel. But it was just sitting in the corner of the shop, looking for a purpose. It was an offcut from a friends desk project from a few years back. Ah well. Call me bougie.
Coosa doesn't hold screws as well as plywood, so I had to modify the construction by gluing all of the joints. I had done some tests and found that gorilla polyurethane glue works very well on coosa. It makes sense, a polyurethane glue working on polyurethane foam. I used pocket screws to hold most of the components in place while the glue cured, then added plugs to those holes.
It looks nearly done, but I'd say its halfway. Need to do some more sanding, scrape more glue, paint, hang doors and shelves, build drawers, etc...
Since coosa doesn't hold screws well, I'm gluing a small strip of plywood into the cabinet where the drawer slides will go. it will allow me to screw them into wood and makes the build easier. I'm thinking about making the sides of the drawers out of wood for the same reasons. The cabinet front and the cabinet doors are already made form coosa, so I need to figure out how to attach the hinges. Maybe t-nuts?
Weather is looking good this week, so I will start chipping away at the turbo install. First step is to drop the oil pan and install the oil return bung.
rruff
I was going to use Coosa (1/4") for building underbody storage boxes, but shipping doubles the price! Seems like good stuff, though.
I ended up using EPVC and fiberglass, but I'm thinking Coosa would have been worth it, honestly...
Fenderfour
I think it's a good product, super overkill for this cabinet. After initial glue-up, we had a big rainstorm. I just left it outside. No issues at all.
1/4" seems thin for under-truck stuff. Were you going to skin them?
rruff
Yup. Layer of 18oz on each side probably, but 6oz or none would be adequate for most things.
EPVC works as a core, but it lacks strength and stiffness, and it isn't that light. In hindsight I wish I'd just paid the cost for the Coosa.
Ptron
I took the truck to the local CAT scales a while ago to find out how much the camper weighed and to get information to start dialing in the suspension. The camper is just under 1k lbs, and 200 of that went to the front axle. the rest is riding on the rear. I noticed a fair amount of front-end dive when I took it camping, so i thought some different torsion bars might help. I didn't have specs on the installed torsion bars, but I -hoped- they were the same as the 1994 4 runner, as my truck shares a lot of parts with it. I got some OME torsion bars and tried to fit them. No luck. The 4 runner has two different splines, my truck uses the same smaller spline as the 4 runner on both ends. Unfortunately, I couldn't return the OME bars because my dog ate the packaging.
I started looking for other options. Sway-Away has a whole raft of different torsion bars and I felt like I had enough information to work with someone there to find the right one. After a 15 minute conversation with their tech department, the rep found a bar that would work (Sway-away /Xsway PN 1627). A few minor time-eating issues later the bars arrived.
They are beefy. I think stock is 23.4mm, the new ones are 26mm.
They bolted right in. I haven't had a chance to drive on them yet, as my seats are out while I perseverate on turbo plumbing. I also pulled a rear leaf off to get some free-state measurements. Just like the torsion bars, I don't have a lot of info on them and want to get some higher rated springs and maybe replace the lift block with spring travel. Now I've got the info and need to call some folks to see if there is something off-the-shelf that will work, or if I have to go custom.
Nice build!!! Also, thanks for finding all the parts!!!!
Fenderfour
spent some time getting started on the turbo over the weekend. I'm not 100% sure I want to push to have it done before a trip I have planned in June. If I do, it will not have the requisite instrumentation, and that feels a little sketchy. I did get started on a mod that doesn't require me to finish the entire installation: adding the oil return to the sump.
I bought a kit from an Australian company "HD Automotive". They have been installing these turbos on 2L and 3L (model #, not displacement) for years without issue. Their kit returns oil to the oil pan. Some turbo kits use two oil ports on the block, and I'm not so sure about this. It saves some effort, but the piece of mind of having the oil return to the sump to not isolate the hot turbo oil into some pocket seems like the right thing to do.
HD has a video showing the turbo installation on an LN106 HiLux. In that video, they remove the front crossmember and drop the diff so the oil pan can slide out the front. The LH85 Hiace did not require this. i was able to remove a few skid plates, then unbolt the outside sway bar links to provide clearance in the rear. After removing 16(?) 12mm bolts, and wrestling to detach the oil pan from the RTV holding it the block, the pan slid back and out without any trouble.
I've got someone lined up to tig wled the return bung to the oil pan on wednesday. Then I'll cap it with a AN10 cap and re-install everything. This is probably as far as I will get on the turbo for a while, focusing on finishing the galley and gettting the electrical system ready for the June trip.
Fenderfour
It seems like my build is all over the place. I've got a few projects running in parallel so I don't get too fatigued on any one task.
Current open projects:
1. Turbo installation - The oil drain return is in the oil pan. Making decisions on what to use for intake tubing from the stock airbox to the turbo. Thinking I'll probably use ABS pipe from a home improvement store. It's easy, its cheap, it's not carrying pressure (even though it could), it's easy to deform (use heat), fast to iterate on, and easy to get replacement parts. I can install most of the intake tubing and cap it before I do the rest of the turbo.
2. Galley cabinet - I'm currently priming/painting the carcass. It takes a while as I rely on stable spring weather in Seattle. it's also not my favorite thing, and impatience will create a crappy result. I had cut slab countertop, but I rounded both front corners... I should have only rounded the left corner. I'm pretty sure I'll find a different top for the galley. I'm also sort of working on the drawers. I moved my small woodworking shop and its not ready to work in just yet. There is also the matter of figuring out how to mount the door hinges for the cabinets. Coosa doesn't like holding screws, so i need to bond, or make some kind of nutplate,
3. electrical system - The solar panel is on top, I added the wire pass through a few weeks ago. Most of my use is for 12VDC loads. I've got a maxxfan, a small fridge, some lights, phone charging, etc... I'm also using an all-in-one inverter, mppt charger, and BMS from ACOpower, so overall, its a simple system. I decided to create a single switch box/panel to control all 12VDC loads. I have a small living space and routing switches all over didn't make sense. The panel is a Tanos Systainer mini that I cut the top out of and replaced it with a CNC cut ABS panel. There is a Blue Sea Systems fuse/distribution panel and a 100Amp fuse inside. 12 switches control each of the 12 circuits on the Blue Sea fuse panel.
I added the all-in-one remote screen, and the BMS remote screen as well. It's pretty much a one-stop-shop for my electrical needs.
A quick view inside. Two wires to each switch to provide power to the load and the LED indicator for the switch.
4. Other open items - Headliner needs to be replaced, will probably do the door cards at the same time. I've got kilmat noise insulation for the cab that I still haven't installed. The ceiling of the habitat still needs to be insulated and covered. It's just bare frame and ACM skin. Need to figure out how to carry more than 15 gallons of fuel. There is space where the spare was, just need to find a tank and build a transfer system. Really want to improve lighting while driving. I'm thinking some high-end LED headlights, like Morimoto or JW Speaker, and replacing old incandescent fog lights with a modern driving light. I don't need a hundred lights, just enough to drive in modern safety.
Fenderfour
I've had a small step ladder kicking around my camper to get in and out, pull branches off the roof, etc... I had planned to have a fixed stair on the back bumper to get in and out, but having a portable step ladder around has been too useful.
...but it had this weird handle/guard thing. It's not really useful around the camper, and I thought about removing it, but I thought it might make a good porch.
The panel is a piece of 3/4 Coosa Board offcut I had left over from the floor and the galley cabinet. I removed the plastic organizer on the end of the ladder guard and added nutserts to the handle so I could screw the panel on. The handle stops aren't strong enough to stand on, so I created a bracket to attach the handle to the bumper. The fitting between the ladder and the bumper is a few bits from the hardware store. Sometimes when I'm trying to figure something out, I'll walk around a hardware store, searching for inspiration.
The ladder side has two 3/8" carriage bolts going through. I added a small piece of aluminum angle to provide better shear strength to the ladder extrusion. The domed ends of the carriage bolts act as buttons that fit into the bumper bracket.
The bumper bracket is a piece of 1/8" mild steel that I cut some slots in to receive the carriage bolt heads.
I put some big steel nutserts into the bumper to attach the bracket to, and voila! a porch.
It works great on flat ground, will probably need some shimming on bumpy surfaces.
Fenderfour
I finally got the galley cabinet carcass in. I thought it would take half a day, it took three. I'm mostly blaming the jerk (me) who designed the installation. There are 5 seat track fitting bolts on the bottom and 5 blind screws along the sides that all have to be lined up to get the darn thing in. With the cabinet being made out of Coosa, its stupid light and was easy to lift in and out of the truck as I trouble-******** the issues I created for myself.
It's a little tight in my 6'x6' camper, especially with a bunch of stuff taking up space.
The cabinet houses my power system, which I'd like to use in the middle of June, so I needed to get this thing in. The battery has a series of angle-aluminum brackets that secures it to the forward face of the cabinet (up in the picture just above). I'm keeping weight low and forward to help with balance.
Once the cabinet was snugged in, it wouldn't budge. I can easily rock the whole truck by pulling on it without a squeak or the tiniest shimmy of the cabinet.
MonteroNerd
