Any 7.3 gasser owners?
Ninelitetrip
7.3 / 10 speed has been out since 2020 model year. As people get higher mileage any issues popping up?
If memory serves my 1982 Jeep Wagoneer with a 360 cu in (5.9L) V8 got around 8.x mpg.
I'm fine with 10.5 mpg.
yfarm
2020. Scab 7.3 10 spd 4.30. No issues, no second thoughts. 46k.
No daily driving, 90% long distance highway, towing light trailers, remainder short distance towing 13k lb trailer or severe rocky remote ranch roads.
Looked at a new 2025 F250 FWD 6.8 10 spd, 3.73 XL FX4 CC yesterday at a dealers lot. There is now an additional offroad package beyond FX4 not tremor Also 33” mud tire option as well. MSRP was 57k, not much more than I paid in 2020.
Riversdad
I have the 7.3 in my '21 Tremor. Generally get 12.2 in mixed driving but I did touch 15 on a 260 mile highway drive where I kept my foot out of it.
For a truck that weighs 7100lbs. and is shaped like a brick I can live with 12.
Chadx
♫ Offroad, again. Just can't wait to get...♫
Another poach of my own post with some gas mileage info:
Did our yearly April UT trip but first time with this rig.
Pickup info: 2024 Ford F250 Supercab with 7.3L gas and 3.73 rear diff. Max payload on my truck is 3,195 and GVWR is 10,400.
With Supertramp, my wife and I in the cab, all gear (food, water, clothes, chairs, tools, recovery gear, air compressor, etc.), the CAT Scale said we had 2,315lb of payload and 9,520lb gross weight (4,540F / 4,980R). That is 880 below max. So nice to be that far BELOW max with a heavy duty pickup rather than that far OVER max like on a Fullsize pickup.
Pickup has around 4,000 miles on it so engine may continue to loosen up a bit and slightly improve with more miles.
Odometer reading was 1,413. Tires are changed from stock 275/65R20 to 285/75R18 so 2.1% larger diameter. Corrected mileage is 1,443 miles. This was 540 miles of highway and interstate. 50 miles of that was slower canyon roads, but mostly 75mph and 80+mph as we ran the speed limit + the entire trip. Had strong headwinds for several hours, too. Then four days of gravel roads or slow, rough trails with a few minor sections of highway to connect trails. Then the same 540 miles home of high speed highway and interstate.
108.43 gallons of fuel used per the pump readout. Pickup gauge calculated 11.3mpg. Hand calculated is 13.03mpg based on uncorrected odometer reading of 1,413 miles and calculates to 13.31mpg using 2.1% corrected mile number of 1,443.
Very happy with 13.3mpg. My Tundra with 4.6L V8 with OEV CAMP-X and similar weight, would get the same mileage or 1mpg less gas mileage than the Superduty in same conditions (high speed highway, gravel roads, trail driving, etc.). In the six speed Tundra, I would mostly lock out 5th and 6th and run about 3,000 - 3,200rpm in 4th. The 7.3L, 10 speed w/3.73 rear diff lopes along in 10th gear except when it gets hilly where it would shift as low as 8th (still an overdrive) or sometimes 7th. When it downshifts, it holds the gear rather than trying to prematurely upshift again like the Tundra. So less manual locking out taller gears with the F250 when driving hilly interstates and highways. I didn't record cruising rpm at different speeds, but seems it mostly hung around 1,100 - 1,200 rpm. On gravel roads going 40mph to 60mph, would easily pull 8th, 9th or even 10th gear, though I often locked out 10th and sometimes 9th depending on how long the straightaways were . On the slower sections (30mph - 40mph) or with lots of curves and turns, I'd lock out all three overdrives and limit the transmission to 1:1 (7th gear) to reduce shifting., but was amazed how the grunt of the 7.3 would allow upshifts and holding a gear at such low speeds. Much different personality, as expected, than the 4.6L V8 that liked to rev to make power/torque.
For the trail driving, 4hi was appropriate most of the time. 1st is really quite low and I only shifted the transfer case to 4lo a few times for particular hills or obstacles and also for a few other sections just to play with it. Stock FX4 had plenty of clearance even in some ledges and interesting terrain. Nothing crazy on this trip, though, and limited to trails rated 4/10. I used to run 4lo a lot more in the Tundra and liked manually shifting while in 4lo in that truck. 4lo shifting in the F250 isn't as pleasant in my opinion. The truck holds each gear too long (high rpms) and even manually shifting, it won't let you shift to a higher gear unless the revs are pretty high. I foresee using 4hi way more in the F250 than in the Tundra because of the shift pattern and because 1st and 2nd seem to be quite low even when transfer case is in high range.
Having 34 gallon fuel tank rather than 24 gallon tank has been huge improvement. I haven't yet recalibrated my head around that extra range when planning remote trail routes and so we ended up making one out-of-the-way drive for fuel when, in hindsight, it wasn't really needed. Having 30 useable gallons vs 20 useable is a huge improvement particularly since we've proven the 7.3L will get the same mpg, or better, than the 4.6L when the camper and truck are stocked for a week trip.
I mentioned it before, but also so nice to be able to drive decisively when loaded rather than very conservatively. Fullsize pickups required absolutely slowing down to the suggested curve speeds on highways where the Superduty easily handles the curves 10 - 15mph over suggested which is usually at the main posted speed limit.
Previous rig, the day-to-day handling was sound enough if driven conservatively, but I was always concerned about emergency maneuvers. I typically drove 100% of the time where with the Superduty, my wife easily and enjoyably took the wheel, for a couple hours on the drive down and back, on interstate sections with 80mph speed limit. Great!
More data: With camper on and towing 3,000lb fishing boat on our 150 miles loop to and from a local reservoir, I'm getting about 10.3 to 10.6mpg depending on how fast I drive (70mph to 75mph) and that days wind direction. That is the same mpg to a tiny bit better than the mpg of my previous 2013 Tundra with 4.6L V8, different camper but same weight, and same 3,000lb fishing boat. Very happy that the 7.3L lopes along while getting the same as the 4.6L V8 running about 3,000rpm in 4th gear (1:1) and 5th/6th locked out. Superduty runs mostly in 10th but will downshift to 7th (1:1) or 8th on the steeper interstate hills.
Really hard to ready exact rpm on the gauge, but the following is fairly accurate. This is 7.3L with 3.73 gearing and 285/75R18 tires.
65mph: 1,500rpm
70mph: 1,650rpm
75mph: 1,800rpm
80mph: 1,900rpm
Quoting my own post (above for full details of last years trip, rig/setup, distance and mileage). That was 1,443 miles, with camper, resulting in 13.31mpg for entire trip.
And now some more data from a similar trip a year later.
Quick recap of rig:
Pickup info: 2024 Ford F250 Supercab (so non-Tremor) with 7.3L gas and 3.73 rear diff. Max payload on my truck is 3,195lb and GVWR is 10,400lb.
With Supertramp slide-in pickup camper, my wife and I in the cab, all gear (food, water, clothes, chairs, tools, recovery gear, air compressor, etc.), last year the CAT Scale said we have 2,315lb of payload and 9,520lb gross weight (4,540F / 4,980R). That is 880 below max payload.
Pickup now has 15,000 miles on it (Had 4,000miles last year). This trip was from southwest Montana to Zion for two days and then three days dispersed camping and trail driving to overlooks of the North Rim of the Grand Canyon and the AZ strip.
Odometer reading was 1,715.8 miles for the round trip. Tires are changed from stock 275/65R20 to 285/75R18 so 2.1% larger diameter. Corrected mileage is 1,751.8 miles. This trip was around 1,000 miles of highway and interstate mostly 75 - 80mph. Maybe 400 miles of slower canyon roads and two lane highways (60 - 70mph). Four days of rough gravel/rock roads mostly 20mph - 35mph. And HOURS and HOURS of 2mph - 6mph trails as we scraped our way slowly through several 7 miles stretches of overgrown juniper and brush lined trails or rocky trails.
141.88 gallons of fuel used per the pump readout. Pickup gauge calculated 12.0mpg for the entire trip. Hand calculated is 12.09mpg based on uncorrected odometer reading of 1,715.8miles and calculates to 12.35mpg using 2.1% corrected mile distance number of 1,751.8miles. 7 fuels stops and worst tank was 11.43mpg and best was 12.82mpg.
Interestingly, the tanks of gas that were 75-80mph interstate resulted in similar (hand calculated) mpg as the tanks where we did sub 40mph gravel/rocky roads and hours of sub 4mph trails).
jerstw
Seeing Chadx's truck makes me very sad Ford no longer offers the SuperDuty in the extended cab short-bed; would sell internal organs for a "supercab", shortbed, F350, 7.3 Godzilla, Lariat or Platinum Tremor in the new Marsh Grey or Avalanche color.
Chadx
Until you posted, I didn't know they had discontinued the 148" wheelbase. Now I'm a bit freaked out as I cringe to think what I'd do to replace my truck if it was totaled. The Supercrew is just too long (to park in my shop, the breakover angle and turning radius).
I drive my trucks for 10 to 15 years but if something happened, I'd be hard pressed to find a satisfactory used replacement and the Supercrew just won't work for my use case. Very sad the 148" wheelbase is no more!
jerstw
Yeah it sucks. I finally narrowed down my next truck to an F350 earlier this month, went to the dealer, and he told me they cancelled that cab and box configuration as something like less than 3% of new SuperDuty's sold were in that wheelbase. I get it from a manufacturing standpoint, but regret I did not move quicker. There are still a couple stray's in the U.S. new on dealer lots but they are all XL's with the STX package and there is at least one XLT out there I've been able to locate; one dealer in WI has a new 2023 SuperCab short bed, red, STX but not the 7.3 (6.8), one XLT, 2024 gray with 7.3 and 4.30 gears in CT but dealer not budging much on the price. In summary, you got a sweet truck and hope it stays with you the "10 to 15 years".
Chadx
The 6.8 is pretty much as good as the 7.3 especially for pickup camper and lighter towing. If everything else ticks the boxes I want on a truck, I'd have no qualms with grabbing a 6.8. It does have a different transmission, but again, if you are not towing super heavy, shouldn't matter. 6.8 has the 10R100 which is a lighter duty tranny than the 10R140 the 7.3 gets.
As for the one in CT, even if they are not budging on price, your are getting a wheelbase that is discontinued so think of it as a limited edition vehicle. Ha. Even if they are asking MSRP, that only adds a few thousand bucks to the overall cost of a not cheap pickup and you are getting the wheelbase you want. Trust me, I'm a wheeler and dealer and usually get quite a good price on things, but sometimes you just swallow it and jump on it. I think it's unlikely you'll have regrets spending a few extra thousand because they won't budge on price compared to the regret you'd have from dithering, all the Supercabs being gone, and then you ending up in a wheelbase you don't want. "I should have just paid it and got what I want" will be a bigger regret than "I paid a few thousand extra to get the truck configuration/wheelbase I wanted".
That is all I have to say about that. :devilish:
rruff
If you really want maneuverability, bumping up to the F450 C&C would make sense. If you don't need a backseat, you could do a custom bed and storage for the single cab short wheelbase, in either 450 C&C or 350. More $$$ and work, but... but you could keep the internal organs... :p
weberjeff
Checking in. 2024 F350 w/Tremor package. Just over a 1000 miles on the odometer. Love it. Just one question to the group. With just about 12.3 mpg and the 36 gal tank, anyone put a 58 gal Transfer flow replacement tank in? Plan to be towing 9k trailer and putting a AT Atlas or RSI SmartCap on the bed.
thiranger
Might purchase a 2018 Ford F 250 as a chassis for a expedition build. Gas engine. Any ideas or thoughts? This or I go huge and buy a Stewart and Stevenson
jerstw
Well, they ditched the 148" wheelbase for 2025 model year, BUT they announced it will be back for 2026. Few dealers confirmed when the 2026 order banks opened up last week and it now published in the 2026 Towing Guide (see below):
Ninelitetrip
Excellent.
Chadx
Hope this holds true. Odd the 2026 order bank is open. Not usually the case until July or August.
Ancientsojourners
