Isuzu npr 4wd
CJD
Below is a picture of a cabinet above the sink in the kitchen. I would like to store some kitchen items here. As you will see this cabinet has many wires traveling from the roof solar panels.
Does anyone have a suggestion how I can fabricate a false back panel to allow a compartment for the wires, while isolating space for kitchen items.
Any suggestions, pics, ect?
How much heat is being generated by the electrical installation? how often will you need to access the PV isolator? can you live with reduced storage in this area, in order to provide sufficient air flow for cooling to the electrical installation?
gator70
I don't see heat, but can cut ventilation slots in whatever is fabricated.
gator70
I would have thought that blanking off that area would obscure the access to your PV isolator, which kind of negates its purpose. :unsure:
Good point
My thought was to use a router and carefully cutout a tight hole so the "face" of that switch was accessible.
I could use "stand offs" so the false panel is spaced away from the wires. But those who use the cabinet for kitchen item storage would not interfere by accident with anything .
And create template with cardboard as a first step.
SkiFreak
Crazy Person
Personally, I would not feel all that comfortable placing any significant electrical equipment in a location that could potentially get wet, but as I have said on numerous occasions... it's your build.
iStan814
