Isuzu npr 4wd
CJD
Below is a picture of a cabinet above the sink in the kitchen. I would like to store some kitchen items here. As you will see this cabinet has many wires traveling from the roof solar panels.
Does anyone have a suggestion how I can fabricate a false back panel to allow a compartment for the wires, while isolating space for kitchen items.
Any suggestions, pics, ect?
How much heat is being generated by the electrical installation? how often will you need to access the PV isolator? can you live with reduced storage in this area, in order to provide sufficient air flow for cooling to the electrical installation?
gator70
I don't see heat, but can cut ventilation slots in whatever is fabricated.
SkiFreak
Crazy Person
I would have thought that blanking off that area would obscure the access to your PV isolator, which kind of negates its purpose. :unsure:
gator70
Good point
My thought was to use a router and carefully cutout a tight hole so the "face" of that switch was accessible.
I could use "stand offs" so the false panel is spaced away from the wires. But those who use the cabinet for kitchen item storage would not interfere by accident with anything .
And create template with cardboard as a first step.
SkiFreak
Crazy Person
Personally, I would not feel all that comfortable placing any significant electrical equipment in a location that could potentially get wet, but as I have said on numerous occasions... it's your build.
gator70
Nothing 1 inch from the ceiling gets wet
Look, nice idea in picture below (not mine)
gator70
Front bumper ideas
I’ll start with a winch tray in steel. The NPR comes with plastic bumpers, so those go in the trash.
Then fabricate bumper brackets so the winch is in the correct position.
The last older series of the Isuzu FTR comes with a nice steel rugged bumper.
Will analyze the fit
gator70
Horseshoe shaped dinettes.
(seating / dining areas)
Many habitats have them including mine.
Does anyone have pictures where the design was outstanding?
Are they all exactly the same?
gator70
I'm spacing my subframe and truck frame with a non metal spacer.
So when there is movement, there is less of a frame slap when the subframe returns to the truck frame.
2x2 OAK hardwood
gator70
Maybe on your build that is the case, but that is definitely not the norm. Most spring mounted subframes have no fixed points.
I might not fix any points - I did see one with bump stops on youtube
Just a limit on subframe travel close to the truck cab
gator70
Its time to wire my rear bumper for lights.
My bumper has no holes yet. What is good practice to drill the hole for the light wire and protect the wire from the metal edge after drilling?
Would a over size hole allow the wire to be far from a metal edge?
mog
Kodiak Buckaroo
Rubber grommets are the normal method to protect
Adel clamps to protect/support/limit movement.
Zip tie bases are a popular, easier option to Adel clamps (not as many sizes are needed)
seth.c96
