Unicorn on the Ocean - 1120AF Coming to Canada
whomisi
Small update, big satisfaction, it's driving again
Started up with a whole new fuel system, for the first time in 9 months, like it was running yesterday. What a beast, purred right into life.
Interior layout getting quite well designed now, need to be ready to cut some holes once there is a box on the back.
Arguably overly complicated subframe components being laser cut and formed in the next week or so, will be a big job welding up the whole frame flat and true. I've got the right tools and know an awesome welder to get things close enough. Although the two main box sections have a 5mm lateral bend in them which I'm not sure how to straighten. I guess we'll see.
whomisi
One of those big days where things come together instead of just staring and scratching my head. The subframe is tacked together and came out very close to flat. Although I've come to realise that flat is just a concept to be aimed at, but never achieved. According to the laser, I'm within a couple of mm over the whole length. Not sure how much things will move when my the final welding is done. I guess we'll find out, luckily for me a very experienced and highly qualified welder is going to burn it in for me, so it's got the best chance of staying flat.
I'll lift it off the chassis for the final welding, save splattering holes in all the fresh paint and fuel lines!
camprr
That is some real progress there, must be nice to have it done! Have you decided on how and where to pivot the subframe on the truck frame?
whomisi
I'm going for rail on rail for highway manners and robustness for the chassis. I've got a variety of die springs so I can tune the hold down tension and preload along the length. As well as limit the travel if required. Starting point is 6" of travel at the front.
You can see the hold downs below, just a bolt in the image as I was setting it up for welding.
I had to drill out the chassis hold down rivits and replace them with countersunk bolts for clearance to the springs. The springs are 30mm OD.
There's 1/4" rubber between rail and chassis to keep the noise down.
I know this still leaves some torsion in the box, but on balance it's a better fit for how the truck will be used, and simplicity.
camprr
Are you welding some 'angled tabs' in to guide the frame back into the right position when they meet up again?
whomisi
Sort of, bolted to the frame but same idea. Taller than the maximum travel, adjustable height to set them snug to the frame. And with a UMHW slippery plastic plate to save the paint. 5/16 steel, formed and welded, silly strong.
whomisi
And for completeness, this is the bracket I designed for holding the rear of the subframe to the chassis. This connects close to some diagonal braces that connect to the rear cross member. The factory cross member is welded to the chassis as well.
This is part of the winch extra structure so it should tie everything together nicely.
Four 5/8 bolts per side, grade 8, torqued FT.
I didn't put it right at the very back as I didn't want the box flopping around too much, it's halfway between the rear and the rear spring hangers. Tough balancing act for highway manners, off road articulation, and limiting box torsion.
GR8ADV
Great stuff. I could never do this.
Curious, and maybe I missed it. By extending the frame rail from 3.65 to 4.2, the bending stresses (roughly speaking) in the beam rail increase by about 30-35% +\~ over what it was designed for. Did you have to strengthen the frame rail itself to account for this. Or is it covered elsewhere.
If you have addressed this and I missed it I apologize.
I (we all) really appreciate you taking the time to post all of this
whomisi
Good question. Mercedes provides a guide, which can be found on their website through the "Builders Portal", on how to extend/shorten the chassis and that includes adding reinforcing profiles inside the frame.
It also gives pointers like if you extend beyond the longest standard wheelbase, then increase strength. These screenshots are from the guide which I translated.
There are also requirements for cross member spacing, as well as maximum length that one section of driveshaft can be before a centre bearing multi part driveshaft has to be used.
On top of this (literally) is the subframe, which spreads the load along the length of the frame reducing the bending forces on the extended section of chassis. For reference, I have used subframe box sections that are 3x6x0.188 in approximately the same grade of steel as the chassis, which is stronger than your regular mild steel. The cross member and the reinforcing parts are also this same steel, laser cut and formed from 1/4 plate.
This reminds me why it's taken two years from buying the truck to getting back to a driving chassis cab.... now I don't feel so bad about the slow progress!
whomisi
Time for the cliché photos of the "subframe test", which is no way an actual test since there is no load on anything. Anyway, it looks cool so I'm posting it.
It's also occurred to me that the stiffness of the box will far exceed any kind of steel subframe. So in real life, I feel like the box in unavoidably going to take all torsion that goes into the frame and making a stiff frame will make little difference to that fact. Either way I'm happy with how mine has turned out.
The springs are in place and I'll give those a test next time I have the truck outside. Photos below are at 5" of separation. I was going to shoot for 6", but this feels like enough plus then I can put more preload on the springs to stop them rattling around.
whomisi
Small update but a big amount of work. I built a slide out mini deck for the stairs to hide under. I don't want the style of stairs that stick straight out but instead the steps will run along side the truck towards the back wheel. They will deploy from under this deck.
Using unistrut and some of the old service body on the back I fabri-cobbled this together. Looks simple, but remarkably hard to get flat and square. But it works a treat and it's really nice and stiff so it doesn't feel like it's going to break. I also have a sensor on one of the two locking pins so that if it isn't locked properly, and the engine starts, it will sound an alarm in the cab.
Deck surface is just a temporary solution until I find some nice looking composite deck boards.
whomisi
The panels arrived! It's a 5500x2400x2160ish Total Composites box. I'm grateful that Andreas was willing to supply a DIY kit, I always had that in mind and spoke with him before they moved away from DIY kits. It's been a great experience so far.
The size of the panels meant they turned up on a rack, which took two forklifts to unload. Then trailered to my shop where a crane truck lifted it off and slotted it into place. Apparently I know just the right people!!
This left me VERY short on space, so the next step was to put some vertical bars on the flip side of the rack, then stand the panels up and remove half the racking. I've now got space to work again, a stack of steel box section, and the panels are in close to the right order. The floor being right where I need it.
I stood these on their end one at a time by hand, by myself. Amazing how light yet stiff these panels are. It's nice to finally get a true idea of what the box will eventually feel like. The floor panel is quite a lump, lots of cross members.
V45W_Proto2.5
