2010 4Runner versus...
haven
2010 4Runner Trail Edition
Vs. Jeep Wrangler Unlimited Rubicon
tale of the tape:
MSRP $35,700
engine 4.0L V6, 270 HP, 278 ft-lb
transmission 5 speed auto
4 wheel drive part time
Wheelbase 109.8 inches
Length 189.8 inches
Width 75.8 inches
Height 74.2 inches
Ground Clearance 9.6 in
app/dep angle 33/26 degrees
turning circle 37.4 ft
cargo space, rear seats folded 89.7 cu ft
Curb Weight 4750 lb
GVWR 6300 lb
Payload 1550 lb
Tow Capacity 5000 lb
Fuel Capacity 24 gallons
EPA mpg 17/22 mpg
tires 265/70 R17
Bridgestone Dueler H/T
Traction Aids VSC vehicle stability contol
ATrac active traction control
HAC hill start assist control
DAC downhill assist control
auto disconnecting diff
Multi-mode 4WD
Crawl Control
Multi-terrain select
Multi-terrain ABS
optional KDSS
2010 Jeep Wrangler Unlimited Rubicon
MSRP $32,840
engine 3.8L V6, 205 hp, 240 ft-lb.
transmission 6 speed manual, 5 speed auto
Wheelbase 116 in
Length 184.4 in
Width 82.8 in
Height 72.1 in
Ground Clearance 10.1 in
app/dep angle 44/40 degrees
turning circle 41.2 ft
cargo space, rear seats folded 82 cu ft
Curb Weight 4442 lb (auto trans)
GVWR 5500 lb
Payload 1081 lb
Tow Capacity 3500 lb
Fuel Capacity 21.6 gallons
EPA mpg 15/20 mpg
tires 255/75 R17 32" height
Traction Aids Locking fr and rr diff
transfer case low range
Traction Control
Hill Start Assist
Electric sway bar disconnect
Electronic Stability Program
haven
I tried to post the previous as a table, but it didn't align properly.
Sorry for the long, long message.
Rozzi
Personally, I'd go for the Toyota. The 4.0L is reliable as can be and has a timing chain that will last well over 100k miles. The transmissions seem to be bulletproof and the mods to the 4runners (ARB, etc) make them really stand out. Either way, you are getting a great vehicle. Just my 2 pennies.
durango_60
I think it is a reasonable comparison, and if I were purchasing today those two would absolutely be the finalists.
Mr. Leary
Glamping Excursionaire
If we had some more info as to what you plan on doing with it, we may be able to help more. For example, if you are crawling over rough stuff all the time, go with the Jeep. If you want a more highway friendly vehicle that has some cool stuff to help you down the trail, go with the Yota.
Apples vs. Oranges. Just figure out whether you want an apple or an orange, and go from there.
18seeds
I did this exact comparison. Rulled out the Jeep now it's between the 4runner or tacoma. I'm leaning toward the tacoma
Scott Brady
Founder
I think it is a fair comparison. I see those two vehicles as the best of what is new in the NA overland market (as far as wagons go).
We are setting up a test soon. Test 2010 trucks are starting to get assigned.
Life_in_4Lo
If anything I would think the Xterra would be a better comparison vehicle.
It's a better comparison at a lower price point. I think the Xterra is the ideal bargain SUV. What a great pkg. Worthy choice for offroading.
Naturally, it falls to the FJC as competition but I always saw the Xterra as a bargain 4Runner.
The Unlimited Rubicon is just in it's own category. Nothing else has the ability to run fully open-no doors and in a spartan, offroad setup with solid axles and a tremendous aftermarket. The vast majority that buy a RU are not cross-shopping. JMO.
The natural competitor from Toyota is the FJC. That is the closest thing Toyota makes to fulfill this market.
I just don't see them [4R and RU] as competitors, they are so different.
4R is a premium, offroad suv. A "baby" Land Cruiser.
I guess the only real commonality is the price range but the Trail Grade 4Runner starts around $37K while, I think, a nicely equipped Rubicon Unlimited is around $34K
alexrex20
i fail to see how the Xterra is not worthy competition to the '10 4Runner, or how the FJC is superior to the Xterra. with the Off Road package (rear locker), an Xterra can be had for $27k. the Xterra OR and FJC have comparable approach/breakover/departure angles and similar wheelbase, rear locker, so wherein is the shortcoming?
moreover, i do see the '10 4Runner as a realistic competitor to the Rubicon Unlimited, if only because of the price. to get into a Grand Cherokee, you're spending over $40k to get the diesel and Quadra-Drive II.
zhukoveli
