newbie hi lift questions
garrett
Supporting Sponsor
I found this interesting, can you explain this statement?
I was always under the impression that you want the pulling device to be the weakest link. For instance, if the shear pin in the hi-lift breaks, the load does not fall to the ground, it just cannot be lifted further. If the shear pin is the weakest link, isn't that much safer than a strap being the weakest link?
This is similar in a winching situation. If your winch itself is the weakest link, won't it just stall out? That way, there is no possibility of flying hardware.
Thanks! Maybe I am just not understanding the intended meaning in your statement.
See above. ^^^:ylsmoke: I actually corrected my statement a few posts later to reflect this. ie. the Hi Lift pin being the weakest part of the set up.
emmodg
Garrett, Garrett, Garrett....
Better yet, buy a grade 80 chain. They are proof tested for overhead lifts - 7100 SLL, (tested close to 4 times that I believe for minimum failure). Grade 70 is often called "transport chain", it only tests to around 6500lbs. And grade 80 is only a few bucks more as well!
PS - As has been said before I think: chain WILL stretch - overhead lifts can get as much as 20% out of a grade 80. (Granted, we're not overhead lifting but it goes to show ya', elastic force effects EVERY part of your rig!)
You're right 7WT - poly straps are slick! I've got a 10 foot tree strap in poly from 4X4.
michaelgroves
I understood your statement to mean "of those things not intended to break, if something does break, best if it's the strap/rope. Which does indeed make sense. However, of course if there's a shear-pin anywhere, or other safety valve, then that's second choice - first choice being reaching the stall-out limit of your pulling device!
garrett
Supporting Sponsor
Yep. Should have said "in addition" instead of "corrected". :)
muskyman
attachment.php
Just to add some tech to this thread :D
When you are lifting a car off of people in their bed make sure to leave the handle in the up position. LOL
spencyg
This Space For Rent
Holy crap....that is a very scary story. And they survived with little more than bumps and bruises....amazing.
Spence
Antichrist
That's scary, given how unstable hi-lifts are at the best of times. I'm surprised the FD didn't have something better to lift it with.
Don't really want to second guess, especially since it's hard to tell things by the photo, but it seems it would have been safer to run a chain underneath connected to the hi-lifts so there was less chance of the car slipping off and landing on the couple again.
Having been a firefighter I know there are always times you look back and realize a slightly different method would have been safter.
DanoWall
