Overland Journal: Discovery I, 5-speed
JSBriggs
Anyone care to elaborate down side of pipe caps? I hear a few no's out there but without reasons why.
-Jeff
Crookthumb
One of the nice thing about the Disco1 is that all you have to do to disable the ABS is pull one 15amp fuse and the system functions as it should. I wouldn't even mess with it. It's just not worth the hassle.
It might be more hassle than it is worth, but has anyone tried and used one of the binnacle switches as a way to activate and deactivate the ABS? I think the cruise control clicker switch would work well for this purpose.
DiscoveryXD
Its still too dangerous if you ask me. I had mine kick in twice before I disabled it. Both of those situations were on the street, and not the trail too.
Crookthumb
Yes the ABS does suck, I was just thinking of a way to activate and deactivate it like a traction control switch for those that for whatever reason want to keep the ABS as an option.
Antichrist
More work to install as you need to grind out the inside of the pipe cap some to clear the ring gear. You have to cut off the stamped diff cover and weld on the pipe cap.
You need a modified panhard rod to clear the pipe cap.
Looks is a personal preference so I guess it depends on how much you care what others' opinions are of your vehicle.
Geo14cux
not anymore call Keith [AKA Oryctolagus cuniculus boy]
JSQ
This is a terrible idea.
We don't eliminate the ABS because it's ill-suited to fourwheeling.
We pull the fuse because the Disco1 ABS is effing dangerous.
Turning it on and off with a switch would be like playing russian roulette.
Geo14cux
Kick the south end of a north bound jenny!
but get him while he is Bach"n it. with the smell of taco's around he might be distracted.:victory:
Antichrist
I don't see how a stock panhard rod would clear a pipe cap without grinding away a lot of the pipe cap. Or relocating the panhard rod. You have a photo?
JSBriggs
Ive had mine like this for 10 yrs. Stock panhard, no issues.
attachment.php
-Jeff
Scott Brady
Founder
I do like the idea of the improved fluid volume.
This week is filled with SEMA prep, but I am going to start bringing in the parts for the third-member swap. I hope to do that the week after SEMA, to allow enough break-in time and testing before the trip to Baja.
Here are a few images from Jack's trip. I am getting excited for my little Disco's first trip to Mexico :costumed-smiley-007
DanoWall
