My 05+ Taco Bumper
fabjunkie
Bumper I finished up a couple months ago. Thought I'd throw it out there for those who don't venture over to TTORA. Stick out from the grill is 3.25", I think stock was 3". I don't have a winch yet so I'm waiting to cut the fairlead hole, etc. I designed it to fit up to most 9.5k winches. I'm going to spray it with bedliner at that point. I cut the stock crossmember off and put in a new 2x3 one. So now the skid plate mounting surface is 2" higher than stock. As soon as I can get some access to a tubing bender I'm going to add hoops to match the grill and headlights.
Kodachrome
Nice, how much does it weigh?
I am looking at doing my own since all the ones I have seen are heavier than I would like. I just need the angle, not the brawn, I would like to keep it at 25-50 pounds.
fabjunkie
I think it's around 100lbs. I've got 3/8" plate for the winch tray though, so that probably adds 20-25 lbs. Good luck getting under 50 if you're doing anything other than tube.
dhuss
