1987 4Runner- Expedition Build Up.
I don't think it would be good to mount anything to the drip rails though. It would be easy to bend them if something in the rack bounced enough to cause and impact/impulse load on them. Heck, you can bend them fairly easy with your hand.
Im talkin bout:
just my opinion, but i like russel's idea of going to the frame better. i kinda thought of building the back half of an exo cage and bolting a rack to it. it just seems to me that you would end up with problems over time by bolting to the body. my 2 cents
RU55ELL
Werd. To do what that guy with the white 4Runner did, it would require some structural support inside to bolt to. If you just mount it to the body, it will tear thru the sheetmetal after a while.
S
Scenic WonderRunner
Guest
Sorry...I'm not good at doing these "Paint" drawings.
I have always wondered if you could put a Flat Bar Support just under the topper, at the seam. And then put a riser support above for a roof rack. You could still take off your topper if you wish, and your rack could still be there. You could even use the rack for shade, while your top is off, by putting a thin sheet of plywood or/other on it's base.
If this could work. You would really have No Visible damage to your 4Runner!
Try to zoom in and see what I mean. My red lines looked huge when I did it....but now they are small.
I tried my best...
I am so computer challenged! It took me 20 min. just to get this red line pic drawing to show up! UG! I even had to email it to myself, to get it here!
HELP ME!....LOL
Aloha!
sasaholic
the idea of putting flat steel under the top would work. i did just that with angle iron that ran full length of the bed of my tacoma and welded pads that stuck out past the edge of the bed, and build two hoops over the canopy that the roofrack mounts to. i made pads on the rack and drilled holes through them and the pads on the angle so the hoops can be removed also.
S
Scenic WonderRunner
Guest
Cool!
Add a third riser for heavier loads in the Middle, if needed!
I only had the patients to draw two!
Maybe somebody can help me add the rack on top of my pic! This wears me out!....hehe
Carry On!.....:beer:
RU55ELL
I'm not sure what is between the bed rail and the top, but if there is a rubber seal, I would think some plate would compromise it. Does anyone know what is between them?
sasaholic
i thought my canopy would leak from it smashing the rubber seal on the canopy, but it didnt and ive been in some nasty *** downpours. i only needed to hoops over the canopy, but u could use more if needed its just my rack is heavy duty enough to not need more than the two. i used 2X1 rectangular tube and sucked it close to the canopy and works great.
Hey guys, in need of some help!
We are in the middle of _____________ (Podunk), Oklahoma with some mechanical issues........
We wheeled the trucks pretty hard today, but it wasnt until after getting on the hwy that I notice the truck has apparently lost power. 4th gear I'm barely able to get 50mph. Its also chugging (surging) a bit when left at a constant RPM usually around 3000.
Any ideas? We figure the truck went into safe mode and so we disconnected the battery.
Any thoughts? Power was fine all day before this.
keezer36
Guess:
Improper amount of air, be it a disconnected vacuum or rock thrown up and keeping linkage for opening all the way. Eyeball every inch of the motor.
Idle smooth?
RU55ELL
TPS sticking? Did you ever spray out the MAF? IIRC, these computers don't have a "safe" or "limp" mode, although I could be wrong.
RU55ELL
What size flatbar did you use?
keezer36
Idle is smooth except its gone back to revving up to 2000.
I'd be inclined to back away from the vacuum leak then and concentrate on air intake. Not being familiar with this motor it seems to me you are getting roughly the same amount of air intake regardless of the amount of fuel being dumped in by you stepping on the accelerator. I'd buy a suitable spray cleaner and start going through your air intake avoiding the MAF, there is specific cleaner for it.
MonteroNerd
