Help me plan my van build
nely
19 hwy at 65, 15 around town on economy modes on my dp chip. No build thred. My build takes to long as im on a poor mans budget
Sent from my SGH-T959 using Tapatalk
dsw4x4
I have never gotten better than 15 that was with stock tires and wheels empty. Now I usually get around 13 or 15 empty 35 inch tires (doing 80 plus in the mountains I like to drive fast) Towing I get no worse than 10 usually 11 or 12.
2000 7.3 edge juice chip ( always run on towing) 4:10s 35 inch tires and of course a raised roof poptop. I played with my chip both empty and towing a load.
tow mode always gets better mpgs than stock or performance and the tranny runs cooler all the time in tow mode. Towing in stock mode to tow mode mpgs come up about 3 to 4 mpg tranny temps drop as much as 50 degrees however I know my tranny is on its last leg so that may not be true for a good tight transmission.
Derek
nely
Yes. Im 2wd running 265 75 16 tires with fabtech lift coils up front
My e4od trans has the ever popular torque converter clutch code so I might be able to get 1 mpg better with a properly functioning trans
dsw4x4
185,000 i would not be scared of high miles in these van just take in to account it will probably need a transmission around 200k if it was not used to tow, if it was used to tow it is anyones guess. My last van I 445000 out of with a 351 that was all original.
Derek
RocKrawler
Supporting Sponsor
i read 18mpg and was impressed. But to be clear, your's is still currently 2WD? or did I miss the fix?
2wd, but with the diesel it should drop as much with the conversion as with the gas engine
edit: van turned over to 280K last week and running strong
Overlandtowater
I am glad I found this thread I am new to the forum and this is exactly what I was wanting to find on here... So I guess every one is just about on the same page when it comes to a 5.4? Even if you go with lower gears? The reason I am asking the only vans I can find local are 5.4's or 351's what would your choice be between the two choices?
nely
The 5.4 and the v10 have known issues with the sparkplugs backing out,g shooting out of the head and damaging the threads. Not a good day when you gotta rethread the sparkplug holes in the head
1sweetvan
I believe the "ejecting spark plug syndrome" was fixed at the factory around 2001, give or take. The later years have twice the threads and no problems. The biggest things as far as I can see on those is to use Motorcraft plugs, NOT use a thread lube and to Torque them to spec.
I really like my 5.4L. It does just fine on any hill in B.C., 6- 13% for 15 miles, pulling a 3,000# trailer @ 60MPH.
I would have bought a V10 if I could have found one that didn't have 400,000 miles and a thrashed interior. Clean low milage 5.4's are easy to find and therefore cheaper.
sixstringsteve
well, I have good news and bad news.
the bad: my wife got in an accident today. She's ok thank goodness, but her car isn't. So we need to replace her 4runner.
the good: i may have some $ left over to go towards my van
the bad: I still haven't sold my tacoma, so this van is still just a dream right now
sixstringsteve
more good news: I found a D60 locally for a good price. Hopefully I can pick it up today, then I'll be committed to this van thing. I thought that finding a D60 would be the toughest part.
Steve
Lockwoodjd
