How do you mount that stove shelf?
x2....looks like a cool idea.
Some more of that ...
/QUOTE]
I love the idea of the work light mounted. Is it brighter than your regular back up lights? In the summer time I have to lock up gates and usually need someone to put the car in reverse to see anything. Any info would be great. Thanks!
Hi ! No , it isn't brighter than a Backup Light , but it's an independent and cordless Light that you can use without a Car . :ylsmoke: You can turn it forward , than you have Light in the Truck . Or you turn it backwards , than you have the Light behind the Truck . It's not as bright as Hell , but it's okay ... and it's easy to install and a cheap Gimmick . Tomorrow i can shoot some Pics .
I also have Lights on the folding Table and on the left Box with the Watercock . It's enough Light for a dark Night i think .
	Hey Guys, Not an SUV, but this was my shim/structure/storage solution!
Problem: How to fit a small camper on a big truck?
Solution: Shim it up over the cab and build boxes while your at it....
Thought Yall might like. Great Ideas on here! Thanks! :victory:
I like the idea.:victory: Question: Have you found any issues with wood drawer system not supporting the weight of the camper? Just wondering about weight distribution while off the beaten path.
sloF250, could you explain please what slide system you use for your plywood drawer under the camper? I can't see if you have any from the pictures. Does the drawer simply slide on itself?
thanks
frans
I have some sheet metal laying around, and am planning on ad-hearing it to the bottom of the drawer. Im hoping that reduces the friction. Ill then apply some miniwax to the wood. Lets hope that combo works! Ill update my camper thread when I do it.
