German 98 Blazer build
Started with my laptop mount today...
Driver and passenger legs. Driver side was a bit tricky...
Tacked together:
In the car:
Added a bar to the dashboard:
Start of the laptop mount:
Connected:
Almost finished:
Added some edge protection:
Finished:
My command center. Another gps unit is still missing...
Here you can see how close everything is on the driver side mount:
I`m really happy how it turned out. The mount doesn`t block the sight or hinder with anything in the cab...
chilliwak
Good work Stein, but are you sure you can access your auto transmision shifter quickly when you are in an emergency?:rally_guys:
There`s no difference in handling the shifter with or without the laptop mount. The only thing that it bocks a bit is the key...
Mounted some LED fogs for campsite lightning today:
Switch:
On:
After that pic i flipped the mounts to make it look better:
These lights are pretty bright and only draw about 60mA each...
Also made a mount for the showerhead:
Plenty of hose left:
chilliwak
Stein, you are just Mr fabrication.:Wow1: It looks like you are ready to roll for your next trip.:truck: Since you have done such excellent work I think you need a :beer: cold one. After all it is the weekend and time for some :friday: good times!:wavey:
Well, we had enought :friday: this weekend... :wings:
Took some measurements for the sliders today. Didn`t think that i need that much steel... :Wow1:
I applied for a job today, and should get a call if they take me on wednesday. If so, I`ll buy the steel on the way back...
Btw, should get my water tank tomorrow, so stay tuned for updates...
Shopped at our 1€ store today. Got all those things for about 15$:
Here`s the proof that i can reach the shifter just normal:
Added some anti slip mat to the laptop mount:
Then i took the radio out to add a aux input. Unfortunately my radio isn`t convertable, so i put it back together...
Also got that thing for cheap, but i`m not sure where to mount it:
Then my water tank arrived:
Perfect fit:
Made a mount for it:
Mounted:
My soldering iron died and i had to use my 75W one. Slightly oversized... :icon_shrug:
The pump mounted:
This pump has some serious pressure. I think i`ll put a adjustable resistor in to reduce it a bit:
Finished install:
I think i`ll have to find a better way to store the hose. Suggestions?
There`s another problem i found. The pump doesn`t stop the water when it`s not pumping. So if the showerhead is lower than the tank, it will drain out. Any suggestions on solving this problem?
I could mount the showerhead higher, but that`s not the elegant way...
D
Deleted member 9101
Guest
Put valve after the pump.
First mockup:
Didn`t get much done, just a start with the mounting brackets.I can tell you, this is really tricky to find a place for the mounts...
chilliwak
Looks like things are coming along nicely Stein. Everytime I see metal around your truck I know I will see some cool fabrication soon. I cant wait to see those sliders mounted...:Wow1:
Thanks. Just got a new job today, so i won`t have that much time anymore, but a lot more money. So i should be able to start with my onboard air system soon...
Went shopping again today:
All brackets cut:
This is how they`ll be mounted to the car:
Rear bracket:
Middle bracket:
Front bracket:
I talked to the owner of the shop where i bought the steel, he said he can bend some tube for me. Maybe i hire him to bend some outriggers for the sliders. Will have a look when they`re finished...
Drivers side mock up finished:
Both sides mocked up:
Spent the better part of the day grinding and welding. First one finished:
Welds started looking acceptable:
Both sides finished:
A few cutting wheels lost their lives:
Will give them a shot bedliner on monday, along with the rear bumper, snorkel and swingout...
Also got some wingnuts for the hilift mount:
And a new sticker:
DanoWall
