Bolt on Power and MPG
bldeagle10
1999 XJ Cherokee SE 4.0 AW4 NP231 c8.25 HP D30 stock 3.55 gears no lift 29" kuhmo street tires.
mods:
TB Spacer from some small shop in scottsdale, az
Bosch Injectors from precisionautoinjectors.com
TB didnt give a noticeable change.
injectors, it was a very minimal change, barely noticeable, as far as mpg i havent had the opportunity to test that as i just did the modification.
next up is dual electric fans..
PMA4x4
mods:
All the spacer does is add a couple cubic Inches to your plenum chamber. I got one that matched for free so I tossed it on.
Nightkrawler
98 Cherokee limited 4.0 auto 151k 3.55 gears w/ 31 tires
seafoamed ==> full tune up
neon injectors ($60)
removed airbox restrictor & moved air temp sensor to airbox
already has flowmusta
mileage highway (5 tank average) 15mpg
mileage highway (after, 5 tank average) 17.4mpg
:smiley_drive:
quicksand97
My Lil rig is a 97 wrangler with a 2.5L and on such a small engine every mod I have installed has made a difference, from homemade cold air to catback and in between such as bigger TB, custom TBS, accel coil and wires and more. Ofcourse they all work together as a whole along with my little 31s and keeping wieght to a minimum. My favorite mod is the 4.0L TB and extreme throttle body spacer. I am still debating If I will install a electric fan n order to reduce drag. My only concern is that it only gives it one more thing to fail out in the wilderness. Just how reliable are they? who knows? But for now happy with my rig. Dont get me wrong I do have a long wish list. But back to the point and that is on this little power plant I can feel every single pony added and thats even one pony at a time.
Brigitta
08 JKU, 6.5"lift, 35"KM2's, full boatsides, F/R aftermarker bumpers & tire carrier, winch, racks,.....
K&N filter & Super Chip tuner made a big difference. However I'm running an A/T and have the stock 4.10's. To get the best performance and mileage you need to rev it at hi RPM's in town and turn O/D off on the Hwy.
It's got more torque off the line than it did when it was stock and get's 16mpg in town and about 20 on the Hwy.
PMA4x4
1996 XJ 4dr 142,xxx miles
4.0
AW4 transmission
231 T-case
33x10.50
4.56 gears
bolt on upgrades
Gibson Airflow snorkel
Wix air filter
Precision auto Fuel injectors
99+ intake
62MM Smooth bore TB spacer
62MM bored Fastman throttlebody
62MM intake hole matched
Edelbrock Ty-tec header
2.5" exhaust
Magnaflow hi floae 2.5" cat
Flowmaster series 40 2.5" muffler
Stock plugs
Mopar ignition tune up components
Shell Rotella T 15-40 and wix oil filter
Fully loaded including full roof rack is about 17mpg highway. 12 city.
plans for a 4.6 87octane stroker in works.
JIMBO
:sombrero: '08 JKUR--Automatic tranny/ Aux cooling/ Temp monitoring/ MBRP hardtop rack/33.6" hankook Dynapros/ Procomp Xtreme wheels/ 5.38 diff gears/ 16 to 19 mpg/ O/D use-sat./ cruise conrol-sat/ trailer towing-O/D-sat
Haven't got enough bandwidth to list the rest !
:costumed-smiley-007:wings: JIMBO
Stumpalump
98 XJ
Home brew bored TB helped quite a bit at lower RPM to my suprise. A drum sander and an hour is well worth it. Just sand out the bore the restriction ring at the bottom of the TB being carfull not to hit the part of the bore that the throttle plate closes in.
99 intake helped enough that I would do it when you swap a cracked stock header.
I could not feel the cat back much but wrapping the pipe in front of the cat helps the gasses flow thru the cat as well. Hot gas flows better just like hot oil does. That mod also keeps the heat of the pipe from transfering to the transmission.
Ancientsojourners
