24HOURSOFNEVADA
Nice score on the Four Wheel Camper.  I just read the build on Pirate that's posted.  You guy's are making me think I should have gone Chevy instead of the Ford.
WOW!! amazing on the conversion! great job great treking see you on the trails
Wow, that's a seriously beefy upgraded steering setup!
Nice truck and FWC.
love all the scenery and trails you have taken pics on. new truck looks good too. sounds like you have a good plan as well h2s look good on em
nice upgrade with the steering, bfdiesel did something similar to his old '04 damx. really helped make the alignment last longer.
Jack, I'm about to set out on a quest to improve the survivability of my truck... Starting with the trans crossmember that hangs down. Mine is more or less mashed at the frame rails, and looks to be bowed up in the middle too. All happened before the truck was mine, but I figure that's the first weak spot. Next on the list will be a center skid for the front/middle, probably just back to the new trans crossmember. The plastic and aluminum skidplates on my truck have seen better days, and that big Allison pan is right there waiting to be dented...
I'll try to chronicle my efforts, and if all goes well, perhaps I can even make some extras available to other GM guys. I really don't want to lift my truck much more than I've already done with bags and torsion cranking, so I'll improve what I can and go from there. Thus far, the rear diff is the biggest hangup, but I don't really want to go bigger than 285's, excepting 255/85's if I can find some I like when my 285's wear out.
Keep up the posts, you're inspiring!!
Chris
I spent a week in Baja last April covering 1200 miles/800 of them off road. One of the couples on the trip were in a Chevy Dmax with the Kryptonite steering upgrade (among others), I was amazed at the pounding that truck took. I dare say it got a worse beating than I'd ever put mine through. Only failure on the truck was one of the locating pins for the upper A arm eccentric adjuster broke off when a nut backed off and the A arm got loose.
Kryptonite upgrade is on my list!
