Thanks for the compliments.
If you are at work you may have to adjust your computer's settings, as it may be a firewall issue. I just clicked it from my office and it works.
othewise go
http://www.bajaoverland.com
and click in TECH. I am following the schematic on that same website.
I am staying with a basic, and manual set up for my dual battery mod. No solenoids. I control which battery gets charged and at what times through a Marine switch.(Blue Seas 4 Way Marine Battery Switch (Part # 9001E.)
I may either use the second battery as an emergency "start" battery when my main one is drained beyond its ability to start my rig, OR, switch all the accessories (aux lights, 12v power inside the truck, 12v fridge) to the second battery, and managing the charging system accordingly thru the use of the switch.
I still need to find a 3/8" distribution block with a splash guard, and once I get the battery, need to measure cable lengths, and put an order for them.
			That link is not working keep getting a 404 forbidden.
Truck is turning out great! I'm just about to install my Polk speakers in my LX (not limiting my self to the stock covers).
Keep up the good work, if you cant fix that link can you give us a run down on the dual battery setup? I'm just about to start mine. :elkgrin:
