4307's Canadian Taco Build
4307
Alright!
Lately, winter has finally hit, the weather is cold and miserable.
Today started out as a nice day, cold but nice, so I thought I'd weld the step plate and gusset in place. Unfortunately, I didn't get much done, out of nowhere it started snowing like crazy, ended up packing everything up again and called a day.
I did a little more grinding, fine tuning the fit for the step plate. I managed to get a nice tight fit. The pics below don't really show the fit, It's hard to tell. I thought I'd post them, for for the sake of posting them.
The next step was to weld-in the gusset, to tie the hitch box receiver, to the step plate. First step was to tack weld the gusset into position, check to make sure the gusset surface is level to the bottom surface of the step plate, then weld the length of the seam. Every once and a while the wind would pick up making it hard to weld.
I stopped and took the picture while the wind did it's thing.
After welding the length of the gusset, I had to grind the weld down to maintain the level, flush, surface. I use a Shop Vac to vacuum the weld slag and grinder dust from the inside, box sections. I added some blue industrial lithium grease to catch the weld slag, as mentioned in a previous post.
With the step plate in position and clamped, so the plate doesn't shift, I secured it with some tack welds.
I started welding the back seam, for the end caps, when it started snowing like crazy. I had to pack it in for the day. It was a tough day for controlling welds, the breeze that kicks up was a total pain.
Here's the welds for the back of the end caps.....
4307
Here's the bumper as it stands to date.....
A problem I'm having with the cold weather is the temperature.
I don't leave the bumper in the shed, I keep it in the workshop. The temperature change from the cold to warm causes condensation to form on the exposed steel, I have to constantly wipe the moisture off until the steel normalizes to the room temperature.
I wipe down the bumper as much as possible, but surface rust still forms. I want to avoid this issue as much as possible.
The bumper will be stored for the winter. my shop is dehumidified so condensation isn't really a issue over the winter.
I would love to finish this build over the winter. I still need to do some welding, but not in the house. I made the decision to put the build on hold until the spring.
If a warm, free, nice day, comes along, I might take another crack at it.... We'll see, I not counting on it.
I will be designing the swing out tire gate, cut the steel and dry fit the pieces. I have a few other ideas in mind I'll work on. I'll do this over the winter.
I'll update the build from time to time as things develop.
Until then, that all I have for now.
4307
A Pile-O-Parts ready for spring.....
Donahoe 2.5 adjustable coilovers with weather plating.
Bilstein 5125, 10"
1998, Chevy 63'', 1/2 ton leaf springs for the rear.
Junk yard specials..... Rusty!
Rebuild write-up to come.
U Bolt flip kit...
Can't glue the Chevy's on without these babies.
Ruff Stuffs, Chevy leaf - Toyota axle kit.
They're beefy! 3/8'' plate with three hole choice for center pin location.
Fine thread with 1'' long nuts.
I still need bump stops and extended break lines.
The budget winch....
The budget winch, a KEW 8000.
The winch was bought at Princess Auto on sale for $300.
If it saves my *** a few times it payed for it's self. Eventually I would like to replace it with a WARN 9000 lbs, and possibly mount this winch in the rear. Until then this winch will have to do.
This winch is identical to the Mile Marker PE 8000.
We'll see how it holds up.
I'll be swapping out the steel cable for synthetic, I'll do that before it's installed, when I mount my ARB.
4307
After moving stuff around today, I finally took a pic of my ARB.
Ready for action come spring....
4307
Bow Saw and Storage Tube
Bow Saw Storage Tube....
I never go on trips without one, now I want to make it a permanent item in the trucks tool kit.
This is a super simple solution for storing the buck saw.
The storage tube was made from scrap PVC tubing and end caps I found laying around, while cleaning up the basement.
I cut the tube to length, lined the inside of the end caps with pieces of scrap tool chest drawer mat. The mat acts like a impact cushion.
I made one to be mounted in the truck and one for the Kayak.
This is not a exciting project, but this Bow Saw is pretty cool in my opinion, great rugged product. I have to show you how the saw pieces together.....
I'll start with the storage tube....
Self explanatory.
The Bow Saw....
Bow Saw in the tube...
I'll find a good accessible location to mount the storage tube, holding it in place with some PVC U-clamps used to secure PVC pipe to ceiling joists.
Big Wow! eh? My best build yet.:victory: LOL
Its a cheap trick.
Lately i've been digging around sorting, taking stock of the Pile-O-Parts.
Transmission oil cooler.....
Electrical stuff
Here's a bunch of electrical do-dads....
Sure Power dual battery management system....
Xantrex 1200 115VAC Power Inverter.....
Xantrex 300 110VAC in cab Power Converter, to power the laptop and on road waffle maker, coffee maker, TV... LOL
Blue Sea fuse block..... to properly manage additional 12V devices....
12V, 55W Tractor lights, rubber wrapped housings.... I'm installing these battery leaches under the truck as rock lights. They'll also be really handy in camp at night when we drop things on the ground, as we rummage through gear looking for something like a tooth brush.
The handy dandy 4 channel 12V remote control device to turn on and off 12V devices, like lights, air compressor, and other top secret devices. I have two remote boxes....
El Cheap-O rear view camera system. Seems to work OK when I rigged it up to test it. We'll see if it lasts....
CB radio.... Uniden 520XL.... future home: the former ashtray.
I'm going with a K40 antenna, It's detachable, I'll attach it for long hi-way trips and wheeling....
ARB air compressor....
Optima Yellow Top
And to help power all these devices.... Optima Yellow top. I've used this battery quite a bit as a stand alone, charging off a battery charger. It main purpose was for in camp power. It's getting a promotion.
Quick Grips.
Quick Fist.....
These things are really handy. I had mounted these on our Kayaks to hold the paddles as we fish, they work great!
I liked them so much I bought more for holding a full size Mag-Lite, mini Mag-Lite's, and fire extinguisher, shovel. Heavy duty rubber holders that can be screwed down or bolted.
jordanP13
