88 FJ62 Rebuild and LSX Swap
Set up the new fuel pump. I cut the OEM fuel pump plate to accommodate the smaller plate on the new pump.
Drive shafts done, cleaned them up and painted them
Floor and footwells sprayed with Lizard Skin. Outer firewall and the underside of the floor was also sprayed.
Fuel tank harness is complete includes a dedicated ground that runs back to battery negative. Frame side of this harness has pigtail ground at fuel filter/ regulator
6 battery ground cables. 1/0 cable, soldered lugs, heat shrink, 1/2" split loom, taped. Dual batteries. Long cable connects NEG posts, 2 bat to frame, 2 bat to body, one main bat to block.
I got a quote for OEM pieces, 4 pieces (both sides) $175.000
Made them myself instead, easy peasy
One of the most overlooked items on the swap parts list are custom brackets, lots of them. Here are some of them
Trans cooler line brackets, trans dip stick mount bracket, fuse/relay box bracket, two fuse block brackets and a radiator hose stand off
Let the harness work begin!
Re wrapped the 4WD indicator pigtail and swapped out the OEM connector for a new Weatherpac
Fuel pump harness from tank pigtail to engine compartment
Radio pig tail. No OEM wiring at all will be used with Radio
5mouse
