flightcancled
Wow that's a monster! Where are you getting all that veggie oil?
Philos,
You have a set of factory sienna slides?
You'll need to mount them on a platform of some sort because they'll be too low if mounted directly to the floor.
Thanks djbonsu. You got the material right but the order is Por-15, FatMat, foam then stock vinyl cover. The foam is this:
Cheers.
Hey philos, I'm not too concerned with the large tank. The load will get spread onto 4 contact points. Just got to make sure it's done right. Just think how much that 7.3 weighs on the frame...That Aux tank for your veggie sounds like it'll be too big. I feel like that'd be a lot of stress on the mounting straps/hardware, no? But the range you'd get is pretty tempting too....
