Batteries
Your battery tested fine now, but one bump in the road could change that. Years ago I had a problem with a battery. It would be fine for days, then all of a sudden...dead. I was told that it could have a loose plate, or all of the gunk that falls off the plates piles & causes a short. Changed the battery & the problem went away. Also as stated. Replace your cables. Get the largest guage you can find!
Thanks Maximus, I've had the same issue in the past so I now use the terminals with the bolt and nut and cables with ring eyes on them, they are 00 welding cable with soldered on eyes that are then shrinkwrapped over a label. I'll do some resistance measurements though to be sure. Back to the first question, I first thought it was the battery because the last several times I went out to drive the Jeep the battery has been dead and that was something new and was occurring after having been driven enough to ensure it was fully charged, the period was also decreasing, that is It would be fine 3-4 weeks of not moving then 2 weeks then 1 then less than one and I hadn't added or changed any electrical loads....And the battery was 4 years old which is mid warranty (85months). So I pulled it out to do a full recharge with the charger and it immeduately seemed to lose a half a volt charge withing 3-4 hours. Besides, that's the most expensive thing it could be......
Did you make yours or buy them ?
Couple of observations:
Optima batteries are AGM-style (absorbed glass mat), not dry cells. You can find dry cells for drag racers and such, but they cost more than your mortgage, don't do as good a job in running winches and such because they don't cycle as freely, and I have never seen one on an off-roader in the last 40 years of running the woods. Manufacturing quality for Optima has declined in the last several years, but they do still make a good battery. Not the best warranty in the world, but a good battery.
Welding cable is generally expensive, and is no more conductive than automotive battery cable. If you have some laying around, fine. I would not go out of my way to buy it, though. In making up heavy duty cables, size matters. NAPA and the like will make battery cables for you in any gauge you want, limited to availability. Get big ones, and ask for arctic cable if it is available in your area. Arctic cable is fine-wire cable (similar to welding cable) that is very flexible, and thus easier to route around in making battery and winch connections. If your local dealer doesn't stock arctic cable, ask if they will order it.
You can solder the lugs if you wish, but I would have them swaged, which is how NAPA will do it anyway. If you want to solder also, go for it, but if all you do is solder, the heat generated by heavy winching can create just about enough heat to melt solder. Don't trust it to be the only joining there is between cable and lug.
As for the battery, for a daily driver, get a good CCA rated battery off the shelf with a good warranty. If you want hard core for winching and rough off road use, get an Odyssey. I have one that is 8 years old, spent more than half of its life on a shelf in the garage, has been drawn down to less than 4 volts recently (left the darned radio on) and it still recovered 100% and is going strong. It is steel cased, deep cycle, thin plated, runs in any position, and is an AGM-style battery
Maximus - I made them several years ago, had some cable that was tail end of a spool and needed new ones as the #4 ga off the shelf cables weren't up to it in my view.
Madizell - Good points, our local Napa doesn't make cables or hoses like many do but it might be worth having a new set made next time I go to town. I am thinking about taking the battery to the nearest interstate battery store and seeingif they will go ahead and warranty it for the reasons you suggest, it is about half way through it's warranty. Failing that I'll likely go to at least one Odyssey.
thanks for the input guys
Throwing out my opinion, based on facts of how electricity works. First fact, electrons run on the "outside surface" of a strand of wire. More strands, less resistance as you allow a more free flowing path.
Take two 4 ga multi strand cables. One your typical auto cable, one your typical welding cable. Count the number of strands. An auto cable might be as low as a dozen, maybe up to about 50 strands. Welding cable typically will be in the low 100 and might be up to a few hundred strands. Overall capacity is the same based on the load rating of a 4 ga cable but you will have less current/voltage loss with the welding cable over an auto cable. A bonus is that the more strands, the more flexible is it.
With everything else being the same, a higher strand count will be the better choice for cable, especially if you are building your own.
As for a battery choice, been really happy with my Sears Platnium battery.
This is true for AC current, not so much for DC current. The skin effect you speak of becomes more predominant as frequency increases, and really becomes significant in the RF range. So, for DC power distribution, skin effect is not an important consideration.
I would agree with cnynrat on that one. A solid copper conductor would probably be your best bet for carrying a heavy load without generating excessive heat, but it would be a bugger to route such cable. I suggest arctic cable only because of its flexibility which is handy under the hood. But it is not required. Cross sectional density is what you want. Welding cable actually has less cross sectional density gauge for gauge than standard stranded cable, and is made of fine wire for flexibility reasons, not for reasons of conductivity.
Bottom line is that you can have cables made to order, and they are not really all that expensive, nor do you need to seek out exotic cable material to get good results. All you need is cable large enough that the cable itself is not the point of greatest resistance in the electrical circuit.
I used to have great luck with Optima's but in the last 4 years the quality is just not there. I rarely get over two years service out of any battery, of any price. I am to the point that when they get to two years age I plan on replacing them anyway. They then go to someone with a forklift or similar equiptment where they are not having to rely on them as much. If I am going to be out in the "boonies", I always have another vehicle along; or I will carry a second known to be good battery. I am done paying $150 plus for batteries though.
Thanks guys, interesting on the cables, I had assumed that the high strand count cable was the way to go but perhaps not the best afterall, I'm going to put it all back together and see if it starts, the battery is down to 12.75vdc tonight. I also cleaned up the battery tray, cut a rubber mat for it and have cleaned the terminals and clamps to help minimize resistance to the cables, which seem to check out ok with my meter.
sure been an education, thanks
5mouse
