For those of us who camp in the sticks and can not have a ground fire,what type of item do you use for your camp fire to keep it off the ground?
The camp fire in a can is a nice unit and works fine, but is a bit spendy.
We go to the ocean and use a wash tub.
For times when wood and BBQ fires are band from fire restrictions, I use a propane fire pit I made from a plow disk.
Video of propane fire pit.
[ame="http://www.youtube.com/watch?v=q4agaTN16c0"]YouTube - propane fire pit[/ame]
Side note: some rocks pop when heated but the lava rock has been fine.
The wash tub has a plow disk on the bottom too, just hard to see as its cover with sand.
Side note: When I make build another wash tub fire pit I will make the pipe holding the tub up a lot shorter. Hardly any heat goes down and the lower it is the farther you can be back from it and feel the heat.
