Checking M-416 wheel bearings
mep1811
Gentleman Adventurer
Can the bearings on a M-416 be checked like that on a car by jacking up axle and checking for movement?
Also, has anyone installed a grease fitting in the hub to add grease to the hub?
Thanks
Yes, but the stock axles are pretty easy to disassemble and repack - just make sure to get the right socket for them.
I would check the bearings in-hand if possible - or just replace them if you are concerned. Cheap insurance.
You could drill and tap the dust covers to install a zerk, but it's just as easy to remove them, IMHO.
Wolfbox
