I never did ask, I just assumed. Does the base camp tent come with a foamy mattress inside or do I have to get one made?
For those of you that are already pulling them around, what ball are you using? A 50mm and a 2 inch are close, but wanted to be sure.
Andy, most people that got base camps went to Cosco or Sams club and bought one of the memory foam mattress toppers or egg crate foam. You can now get them with a mattress cover.
No biggie.
Thanks
Dendy
Best I found:I was thinking of riveting 2 D rings each side and use a bungee cord across... I figure I use bungees all the time in camp anyway so it's a bonus transport mode...
Down side, no one has the D rings in the store... McMaster-Carr has them, so that may be the route I go.
I went to Tractor Supply and got a handful of boat-type lash-down points; they secure with two screws/bolts and only cost a buck. Then I got a bundle of flat bungees with big hooks at Costco.For those you have traveled with the storage boxes with stuff in them... should I figure out a way to run a bungee across the front to keep them in the slides... I am not worried about them falling out, just banging back and forth. Thoughts?
Yes, The tanks that fit PERFECTLY are made by Manchester and they are the 10lb tanks (#10).
They are manufactured in Cookville, Tennessee.
If you do a google search, you will find many sources.
This one shows them in stock:
http://www.bigpinespropane.com/parts+acces.htm
I got mine straight from the manufacturer, but cannot find the invoice. If I do, I'll pass that along as well.
Thanks
Dendy
