Coolers
Lostmanifesto
Traveler
I know fridge units are the popular way to go but I am wondering if any of you have any opinions on coolers? Most seem to do the same thing but some advertise "will keep items cold for 5 days". Thoughts? Good luck with a certain cooler? Does the metal Coleman cooler really work as they say?
Any info for those of us that don't need or can't afford a fridge :)
Thanks,
Jordan
I have had some success with the marine versions. None of them really hold up well to the desert heat. I have wrapped mine with heavy moving blankets and in the shade and they will last for maybe three days if not opened constantly. Thus brings up my usage of a cooler for drinks separate from food items.
A third cooler sometimes comes along with dry ice for frozen meals prepped prior to departure and or ice cream.
I googled cooler comparisons a while back and came across a Youtube video of a comparison between several different coolers. The top contenders (of those they tested) were the Engel (same as a Yeti) and a MaxCold. Both managed to keep ice for the same amount of time, but the Engel was obviously the tougher of the two. The Engel/Yeti are "bear proof" when you use a padlock to secure the top. I'll probably break down and buy one someday, but for now I'll just keep using my MaxCold until I get into big bear country.
I have 2 Yeti coolers and really like them. They keep ice well and dry ice will not hurt them. They are pricey, but I highly recommend them.
What my dad did, and I followed suit....
Regular coolers....
Make a cover out of foil insulation(the ripstop stuff can be sewed)... and there are some pieces of the pink foam insulation between that and the cooler..... Took my cooler from a wkend, to almost a week... launched on friday night... and got Ice on Thurs AM.....
If you can keep it out of the sun, and better insulated... you will be better off....
Chase
I have had one of the "metal Coleman" for about 10 years, it works great. I can get a weekend camping trip out of it in FL with no trouble.
I have a yeti 80qt and an engle 85qt both will keep ice in 7o to 80degree temps for a week. Oh and the engle is for sale. If you dont want a fridge spend as much as possible on a cooler you wont regret it.
I have 3 metal colemans (two stainless and a green one), plus a bunch of regular plastic coolers. The metal is definitely more durable, and I can get about 3-4 days of cold out of it, assuming I'm not using it for beer (lots of open/close).
I think maybe even more important than the type of cooler you get is your usage. If you have a family and stay out for many days away from ice refill, you might be better spending your $$ on more cheaper coolers than one really nice one...as has been mentioned, that way you can have one cooler for drinks, one for food, and one for frozen.
I have a fridge, but that's recent. Before that I went with the 3 cooler approach and could go 5-7 days in very hot temps (90-100 in Washington) with frozen food using a dedicated dry ice freezer cooler + drinks cooler + cold food.
What I'd do is keep one cooler full of drinks and ice. All the food in a separate cooler and frozen food at the bottom of the 3rd cooler + drinks at the top (where they wouldn't freeze from the dry ice). Once the beverage cooler was about 1/2 full, I'd do a mass move/refresh from the freezer cooler to the beverage cooler. That way I'd only be opening the freezer cooler a few times/day, but the beverage cooler was opened a lot...the cold drinks would basically act as the ice once the main ice would melt (it would last 2-3 days)...and remember a 50 degree drink on a 90 degree day feels a lot colder :) Honestly, it was a lot of work, but it worked great. I picked up my stainless colemans on discount at $60 each (yes, great deal), so I had the coolers, so wasn't too expensive.
Now, I have a fridge, it keeps my drinks cold, I still have a freezer cooler, and my battery lasts 4-5 days w/o charging and I spend more time enjoying camping than worrying about moving crap between coolers :)
One thing not mentioned, but often overlooked is that a solid block of ice will last longer than chipped ice. A couple of pastry buckets from the local grocery store filled and stuck in your freezer makes nice large ice "blocks".
It might make since to buy a fridge instead of a couple of coolers. Two Engels or Yetis = $450-$600. Which also takes up more space and weighs a lot more than a fridge by itself. You can get an Fridge from several vendors here and only spend $600-$1000. It's something to think about. Safe travels.
I was reading up on dry ice recently on this forum and here's what I learned and applied last weekend. Using a 50 quart Rubbermaid cooler from Costco, I used four 5lb blocks of dry ice and put those at the bottom. On top of that I put 10lbs of regular ice. We made sure to freeze the bottles of water so they would also act as ice yet drinkable later on. This method lasted over 48 hours with minimal melted ice. Though nothing was really ice cold, everything stayed cold enough from getting ruined in 90* temps and the sodas and beer were cold enough.
The dry ice kept the regular ice frozen, keeping everything cool. I hate having to deal with soggy food in the middle of a trip. If I were to go on a longer trip I'd do the same thing with my 100 quart Igloo cooler. IMO, a good cooler will definitely help but no matter what, ice will melt unless in a freezer. I had never used dry ice before and I was really impressed. I'll definitely be using this method in the future.
that is a really good idea. I may try that.
I have also researched pykrete to help slow the melting process. Here is a link for those not familiar with Pykrete. http://en.wikipedia.org/wiki/Pykrete
rocksandtrails
