Howdy,
TThe first one lost some volume after a few years on landing on rocks on it. So it probably went from 170 liter to around 165 liter.
It is an Elgena Nautic water heater.
The aux tank actually has a very thick bottom on it. Thicker than the rest of the walls. Considering the abuse I gave it, I think it held up pretty darn well.
Front Runner Wind Cheetah Slimline Roof Rack
I thought I would share the latest configuration on the roof rack. I was documenting some new products when I realized I hadn't said much about this on the thread. So here we go.
This is the Front Runner Wind Cheetah Slimline Roof Rack System for the Land Cruiser 100 Series. There's a lot I like about this rack. It's very light, as under 70 pounds. It is very strong. I've had 8 guys standing on it before. It's very streamlined, at 2" tall. But what I like about it the most is that it is extremely versatile.
The floor of the rack is a series of "T" slot extrusions that hold 8mm hex headed bolts. So you can add, move and remove just about anything you like to it. The set up in the photo is my event set up. It shows a great deal of what is possible. Here's what is on there.
Eezi-Awn Series 2000 2.5M awning
Front Runner Accessories
- Stainless Steel Table, mounted underneath
- Dual Can Holder
- Single Can Holder
- Bike Mount
- Shovel Mount
- Axe Mount
- Hi Lift Mount
Alu-Box Pro Case, storing a Eezi-Awn Rec Vee Panel Set for the Awning
The Hi Lift mount is designed for use on the side of the rack. I made a couple simple flat plates to span several slats, the mounted the Hi Lift mount to them. Quickly turning it in to a rack top alternative.
I can have all of these items off and a roof top tent mounted back on in about a half hour.
Cheers,
I checked out their website and didn't see it - can you post the link to it?
Thanks Paul
