off-roader
That's Mitsu ensuring they implement the KISS principle...
Not that unusual. Jeep Rubicon lockers run on 6psi.Correction... Locker Compressor.
For others reading this thread, the Mitsu locker uses a low pressure system. You actually have enough power in your lungs to actuate the locker. Other Air locker systems (ARB, etc) i've seen use a much higher pressure system. That said, the Mitsu compressor is a low pressure low volume compressor which IMHO helps keep it quiet and un-noticed when in use.
So will all of the tank mounts be moving up? If so, that's actually an easier procedure than making new tank brackets. Crap! Another project for me to do.
