Is the design of the 3.9/4.0/4.2/4.6 inherently bad?
Piston slap on new gm v8's?I am a Toyota fan, but there has never been a more reliable gasser IMO that a chevy small block. Including the current ls generation.
Bosch v8s have problems, I'll never own a rover with that setup. The GEMS and earlier stuff is great as long as you maintain the cooling system, and sometimes that means paying 3X as much for a replacement radiator as any other brand. I think 2nd and 3rd generation owners who paid 1/20 the sticker price of the vehicle find it hard to spend almost 1/4 the purchase price on a radiator and the overheating begins.
Other than the cooling system these are very durable vehicles in stock form.
Every engine has a weakness, the rover weakness just happens to be suicidal if not addressed.
the last of the GM small blocks had coolant sealing issues on the intake that would trash the block if not addressed
the current crop has awful piston slap on just about every other truck over 70k
I've helped multiple friends do headgasket or replacement block on 22re, they do NOT last forever
I've replaced 2 AMC I6's with rod knock to the point where it would throw if driven much more, and the crank sensor on the EFI versions will eventually leave you stranded.
The design of the 3.9/4.2/4.0/4.6 is just fine.
The problem is that in the 40 years the engine was produced, the design didnt evolve as much as owners' expectations evolved.
Just because it leaks a little oil, makes some ticking noises, doesnt have as much power, and doesnt get great fuel economy... Doesn't mean theres something wrong with it.
Look at it on the plus side: what other engine, in a 2004 vehicle, could you field strip down to the block and rotating assembly while still mounted in the chassis, using a pretty limited selection of basic hand tools? And then re-assemble? Maybe a Jeep 4.0 inline 6, not anything else I can think of.
"The wings are not on fire!" :sombrero:
Do you include vaseline as a basic hand tool? Because you'll need it to prime the oil pump. And I guess you'd need a fancy allen head socket since that's what holds the starter on, and you'd need to pull it to get to the oil pan and bearing cap bolts? Sounds like a pretty well stocked toolkit to me.
And a full gasket set to put it back together. I always carry that.
Maybe if I didn't have so many tools and spare parts weighing me down I wouldn't get stuck so much?
Got any evidence to back that up as fact?
No engine can pass emissions unless it idles and cruises at 14.7:1 +/- 0.2. It must be so in order for the catalyst to function properly. If they were truly running lean, they would emit excessive NOx, and then they would fail emissions testing.
I'm not sure how to respond to this other than: re-read my post. I neither said nor suggested they leaned the fuel mixture. That would be as ridiculous as.....well...spending all that time responding to a post you didn't read properly.
Guess, I should have double-quoted you and EvilFij, who made the statement about running lean, you appeared to agree with since you quoted him and said it was fact. Also, you don't melt pistons from running hot. You melt pistons from running lean. ;) So if you don't agree with EvilFij about it running lean, why did you make a statement about melting pistons?
If you want to split hairs... the oil pump only needs to be primed with vaseline on distributor-driven oil pump engines (pre-serpentine belt). The starter does not have to be removed to remove the oil pan. It does have to be removed to access the cross bolts at the rearmost main bearing caps (4.0/4.6 engines only).
I've logged lots of hours working on these things, that probably also contributes to the comfort level I have with them. I stand by my opinion that there is absolutely nothing wrong with the Rover V8.
Me too! It may not be get the best gas mileage but it works fine.
Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
Sounds like a bunch on denial to me .... all of these motors are excellerated timebombs!
here are the facts...get a TopHat lined Rebuild
Why?
Land Rover UK introduced the aluminum V8 engine in the late 60’s after falling in love with General Motors Buick 215. It was the perfect engine given the vehicles weight distribution, which was somewhat on the heavy side and the 215 offered the balance, coupled with performance they so desired, or did it?
Over the years the engine has gone through minor design changes in an effort to resolve overheating, premature wear, subtle noises and yes, outright failure. The flaws have cost the company and those who have been driven to own this brand. But the who’s who of the automotive universe still could not keep their hands off it, including BMW, Ford Motor Company and now Tata automotive manufacturers of India.
Porosity in the casting, engine management glitches, and poor steel liner design have been present from the start. Then the little engine is put into a 2045 kilo truck and introduced to inherent heat and you have the perfect storm for failure. Aluminum does not like heat and instinctively reacts adversely. The engine could not help but be put in this service environment as the discerning owner used their vehicle like it was intended.
It has been practically speaking, like a gremlin living in these engines that kept the owner hostage to a temperature gauge among other things. Soon the V8 would experience a make-over that has long been overdue.
The Brits had already been working on a top hat liner system going back to 2001, but the supply of cheap, new short blocks kept the discovery and adaptation at bay in the USA until lately. Why? because the failure rate increased substantially! Installation of a stronger machined top hat liner or cylinder sleeve would bring resolve to this genesis challenge, by allowing more even heat transfer, perfect fit to piston and then a hot seal process to the water jackets to close intrinsic porosity and fatigue issues in the aluminum blocks.
Simply not true. Unfortunately your experience is with a D2, and those engines are in a whole other league of problems. The earlier Rover V8's have a much lower incidence of block issues. I've owned five Land Rovers and the only one to have a block problem was my 1999 D2. The others are still going strong, some of them with mileage approaching 200K. Head gaskets are more frequent on all of them, but I really think that's from lack of cooling maintenance on old trucks coupled with fastener problems. Keep the cooling system in good shape, install good head gaskets with studs, not bolts and they will hold for the life of the engine. The last two engines I did head gaskets on went to 160K and 170K respectively before needing them. There are plenty of Rover V8's with 200-300K on them and doing fine.
Fj89
