pilosopo, did you have to get longer shocks or anything with the 1" springs or was it just a straight swap from OEM?
There have been a few posts on other forums that make it seem as though the synergy springs may handle weight better than the AEV offerings, but it's really conjecture IMO as to whether or not this is true.
There's no doubt that the AEV offering is a great one, and priced reasonably.
For me it boiled down to this. I have no intention of going to 35s.
Gold Mountain in Big Bear was about as difficult a trail as I'm ever likely to see in my DD rig, and I did it on stock suspension and stock tires. Would it have been easier with bigger wheels and more lift? Sure. Did I scrape where the other JK Rubicon Unlimited lifted 3+ on 34s didn't? You bet. At the end of the day did he make it anywhere I couldn't go? Nope.
The AEV setup is optimized around larger tires, including said 35s. That means it has bumpstops designed to allow for 35s with stock flares. In essence, you gain lift but no additional up travel over stock.
The synergy setup provided me spring rates suited to the weight of Jeep. I can fit a slightly taller tire such as a 255/80 (likely my next change) or a 285/70. I also gained quite a bit more up travel as I'm still using the stock bump stops. There's been a marked improvement in my Jeep's ride as I no longer hit the bump stops over expansion joints and the like.
And I can still fit into most parking garages. That may seem like an odd thing to be worried about, but I love road trips in my Jeep. Being able to park mostly anywhere is definitely an advantage.
So for me, and how I use my Jeep, it's ultimately a better fit. I love the looks of the big lift and tires, but I didn't need them or their issues to do what I wanted to do.
Do you think the OME Nitrochargers are the same compression/ extension length as the Rancho's you are running now? I was thinking Nitrochargers too but don't want to put any stress or pull on the stock break lines.
Thanks for the reply, you've given me a lot to think about. I agree on the parking garages, especially outside the States. Most are 2m and when you have 35's plus a roof rack, you are not going to make it.
Pilosopso,
Any further input since you have been running them a bit longer?
Have you disconnected the sway bar yet? With stock links did it lock back up easily when attempting to reconnect?
Poly Performance suggested the Fox IPF shocks. They seemed a bit shorter than the OME nitrochargers... That may be another shock possibility.
Definately interesting about your change in shock choice. My Jeep is not nearly as laden as yours. Stock bumpers, no roof rack, no winch, really the only "weight" is that I consistently carry about 45 to 50 lbs in the vehicle in tire repair, first aid, recovery strap, static tow strap, extra scissor jack, small misc tool set, etc...
However when I go camping it becomes anything goes and I often find myself with 2 or 3 passengers, coolers, sleeping bags etc....I keep trying to cut down on the number of people I bring but really..... Who can say NO to bringing a buddy into the great outdoors
I definitely don't want to create too harsh of a ride so maybe the Rancho's maybe a good bet. Especially after how well you say the springs alone are handling the weight. However the OME I can get in the stock dampening and get the Rears in slightly stiffer dampening to assist in towing, gear transportation, and if I'm lucky.....
I have been considering a J30 or J180 down the road and may decide to go firmer in preparation for that.
But that decision should only effect the dampening of the shock not ride height.
