M416 trailer build my brother and I
That's awesome! Are you tracking the cost of building something like this? Wondering what a diy like this costs.
Sent from my SPH-L900 using Tapatalk
So the tongue box that he had on it was scrapped and he went another way with the box. The sheet metal had one bend put into it and the rest had to be welded together.
So here is the new box shape, the same as the trailer tub. No Harbor Freight tongue box here, it's all home made.
The tongue box is an extension of the tub.
The start of the tailgate.
So a few more pictures. The fenders were purchased at Northern Tool, they were not wide enough for the tires so the fenders were cut in half and extended a few inches to accommodate the tires.
Here's the fender on the trailer. You can see where it was extended on these pictures. You will not be able to notice it on the finished product.
Here's the lid / top that was fabricated, it was opposite of the bottom. Unlike when we worked on my lid the tub is square on this one. It makes it much easier.
The finished product of the lid. This trailer is going to weigh a lot more then my trailer.
The axel and springs are 3500 pound and the lug pattern is for a Toyota Tacoma.
Here's a few more pictures that I just found. This is the tongue jack from my trailer that was changed out. This trailer is a little taller so we will be able to cut the foot plate off and replace it with a wheel.
Here are some shots of the tub being built. At the metal shop you can get them to place a bend in the metal. So the first angle was bent and the other was welded on.
The top welds completed and to front of the tub welded.
Why would you not have them bend it twice and save all that weld time?
Good question, the bend has to be at least 9 inches apart to fit on the machine, so there's the issue, I think the second bend is 6 or 7 inches from the first. If they would put the second one in there it would save a lot of time.
Here's a few more pictures of the progress.
The main box open and the start of the roof rack.
Roof rack with the adjusters on it for the RTT.
Both boxes open.
If you look at the center of the tongue box you will see the winch for the generator.
Next it's going to be painted and then all the small finishing touches.
Here's a few of the finishing touches. Mounted the vin tag on the tongue and had the sheriff come by and inspect it. The tags will be next.
Of course you have to have the bottle opener.
Wood inlay in the tailgate.
The wiring for the battery box. I know it's hard to see but it's a six switch marine switch to operate the lights.
It has not been weighed yet but it's going to be heavy. It's well built and bullet proof almost like this.
The floor in the garage was repainted, the black trailer sucked all the light out of the room. My brother needed to brighten it up, he said it was too depressing in there.
Some final pictures of the trailer as it is finished up.
On board air.
Another picture of the air hose and bottle opener (some of you my recognize the insignia on the opener), a little special touch.
A few more pictures from the inside of the front box with and without the shelf.
The winch controller and scissor jack handle.
OchoSolo
