MIssion Overland Trailer Owners page
well ive read all 113 pages... we just returned from a 5 day wheeling and camping trip to Windrock Tennessee. Rain, snow, way below freezing temps and mud... fun was had! Stayed in a KOA on way home and woke up to -5F, but we slept like a dream. I added a 300ah LiPo, Renogy 40A Charger controller, solar was on roof before i got it (used '22) so not sure on how many watts it collects, but am in process of redoing the electrical (breakers, shunt, 3000w inverter and wired for 400W portable solar) also adding a 20A breaker to WFCO for the truma combi to be run on shore power vice propane if we are at a KOA or state park temporarily and save propane for the back country. We added two 2gal Rotopax to the fridge and battery doors, paper towel holder on end of the kitchen slide, used some 2in pvc T fittings, two 90* and two 45* to shoot heat up towards the front but still shooting it across the standing area. Also a 3in foam mattress its legit!! Plan to eventually get the AC upgrade for the roof seeing as we love in SE. Also L track to exterior near kitchen and on interior ceiling with a bungee net to store thinghs out of the way. Whats largetst tire anyone has added?
The day i got it and the day after we got home from Tennessee. Not my ideal color choice as both my Raptior R and Bronco Raptor are orange but oh well... Maybe i can get a pinstripe guy to do something or get a new wrap over this one, but i imagine that a lot of work or $$$
I think a splash of that orange on it would look awesome TBH.
Ours is the same color and also a ‘22. I agree, not ideal! But is does blend in nicely when you’re out in the wilderness. Orange accent would look nice.
We have done most of the same upgrades you mentioned… 280Ah battery, 400W solar, Truma hardwired to shore power… but I could never get the WFCO to go into lithium mode, so it was ditched in favor of a Victron IP22 to match the other Victron solar controllers and shunt.
I think @mep1811 has 33s…? Maybe? A 285 somethingorother?
Would you mind sharing how your PVC diverters attach to the heat vents? That really looks like a great way to keep those vents clear of bedding and moving air. I’ve been meaning to do something similar.
I have the stock tire size just changed to steel wheels.
I just used regular flexible automotive ducting.
Details in a prior post I made on this forum
My bad, I thought you had bigger tires to match the LC. I should’ve @‘d Raptor Fam for my last question in my post, I like their PVC heat ducts.
The vent unscrews and i used a 2" threaded end
my WFCO has a LA to LI switch
My Nema 5-20p cable showed up. Now time to wire the combi to a 20a breaker in the WFCO to run off shorem power. My blue sea sytstems battery cutoff, my breakers for solar and from battery, my bus bars and shunt showed up as well. Excited to wire it all up!!
New to me 2022 M.O.S. with mods Installed.
Photo of Truma combi tied into shore power now, outlet location on 20 amp run from the WFCO Converter.
Renogy 200 amp hour battery installed and 2000 watt Inverter. My WFCO had LA/LI Switch :-)
20lb propane cage from Exodus Mfg. bolted on nicely. Exodus is working on a cage for a predator 2000 watt Generator to match.
I did find this locking Squatch mount for the generator which is very nice also. I will see which one I like better before bolting on the Generator.
My version of a non electric blanket.
First run set up 2025 Trout fishing opening weekend 2025.
Tow vehicles
Jeep 392
Lexus LX 570
Lexus GX 470
M meadow build
