NEW RIG: 2012 F-150 FX4
Tired of getting the LONG antenna caught on everything, I looked for solutions
Stubby worked good and fit good...........easy 5 min swap
I use Sirius anyways for all my radio needs, but I will report back on how the AM/FM reception is
D45, what is your GVRW and your spring codes? I know another '12 that is looking to improve his suspension.
7,700 I believe
VVGG code.......
Front Springs
1 — 5B326 (RH), 5B327 (LH) torsion bar (F-150, F-250, Explorer/Mountaineer)
2 — 5B326 (RH), 5B327 (LH) torsion bar (F-150, F-250, Explorer/Mountaineer)
3 — 5B326 (RH), 5B327 (LH) torsion bar (F-150, F-250)
4 — 5B326 (RH), 5B327 (LH) torsion bar (F-150, F-250)
G — 5B326 (RH), 5B327 (LH) torsion bar (F-150, F-250)
8 — 5B326 (RH), 5B327 (LH) torsion bar (F-150, F-250)
9 — 5B326 (RH), 5B327 (LH) torsion bar (F-150, F-250)
Z — 5B326 (RH), 5B327 (LH) torsion bar (F-150, F-250)
T — 5B326 (RH), 5B327 (LH) torsion bar (F-150, F-250)
U — 5B326 (RH), 5B327 (LH) torsion bar (F-150, F-250)
6 — 5B326 (RH), 5B327 (LH) torsion bar (F-150, F-250)
C — 5B326 (RH), 5B327 (LH) torsion bar (F-150, F-250)
E — 5B326 (RH), 5B327 (LH) torsion bar (F-150, F-250)
F — 5B326 (RH), 5B327 (LH) torsion bar (F-150, F-250)
B — 5B326 (RH), 5B327 (LH) torsion bar (Explorer/Mountaineer)
D — 5B326 (RH), 5B327 (LH) torsion bar (Explorer/Mountaineer)
E — 5B326 (RH), 5B327 (LH) torsion bar (Explorer/Mountaineer)
F — 5B326 (RH), 5B327 (LH) torsion bar (Explorer/Mountaineer)
G — 5B326 (RH), 5B327 (LH) torsion bar (Explorer/Mountaineer)
H — 5B326 (RH), 5B327 (LH) torsion bar (Explorer/Mountaineer)
J — 5B326 (RH), 5B327 (LH) torsion bar (Explorer/Mountaineer)
L — 5B326 (RH), 5B327 (LH) torsion bar (Explorer/Mountaineer)
P — automatic ride contro(Explorer/Mountaineer)
A — 5310 spring (Econoline, F-150, F-250, Ranger)
B — 5310 spring (Econoline, F-150, F-250)
C — 5310 spring (Econoline, Ranger)
D — 5310 spring (Econoline, Ranger)
E — 5310 spring (Econoline, Ranger)
F — 5310 spring (Econoline, Ranger)
G — 5310 spring (Econoline, Ranger)
H — 5310 spring (Econoline, Ranger)
J — 5310 spring (Econoline, F-150, F-250)
K — 5310 spring (Econoline, F-150, F-250, Ranger)
L — 5310 spring (Econoline, F-150, F-250)
M — 5310 spring (Econoline, F-150, F-250, Ranger)
N — 5310 spring (Econoline, F-150, F-250, Ranger)
P — 5310 spring (Econoline, F-150, F-250)
R — 5310 spring (Econoline, F-150, F-250)
S — 5310 spring (Econoline, F-150, F-250)
T — 5310 spring (Econoline, Ranger)
U — 5310 spring (Econoline)
V — 5310 spring (Econoline)
W — 5310 spring (Ranger)
Z — 5310 spring (Econoline)
Rear Springs
6 — 5560 spring (Econoline)
7 — 5560 spring (Econoline)
C — 5560 spring (Econoline, F-150, Ranger)
E — 5560 spring (Ranger)
N — 5560 spring (Econoline, F-150)
P — 5560 spring (Econoline, F-150)
R — 5560 spring (Econoline, Ranger)
S — 5560 spring (Econoline, Ranger)
T — 5560 spring (Ranger)
X — 5560 spring (Ranger)
G — 5560 spring (Econoline, F-150)
K — 5560 spring (Econoline, F-150, Ranger)
A — 5560 spring (F-150)
B — 5560 spring (F-150)
D — 5560 spring (F-150)
F — 5560 spring (F-150, Explorer/Mountaineer)
H — 5560 spring (F-150, Explorer/Mountaineer)
J — 5560 spring (F-150)
L — 5560 spring (F-150, Explorer/Mountaineer)
1 — 5560 spring (F-250)
2 — 5560 spring (F-250)
3 — 5560 spring (F-250, Ranger)
4 — 5560 spring (F-250)
X — 5580 spring, load-leveling suspension (F-250)
Y — 5580 spring, load-leveling suspension (F-250)
This truck hauls, plain and simple
With the CAI and TB spacer........I can hit 90 without noticing
So much smoother and pulls harder
Hopefully next weekend I can throw on the AFE Bladerunner Charge Pipe
I think the previous (leased) owner added a cat-back exhaust
A section of pipe before the muffler, the muffler, and the tailpipe are not rusting and the upstream area of the exhaust has rust
I know its not stainless, but the aluminized color is noticeably different.........I will snap some pics to see what everything thinks.........Stock or not
My 06 f150 tailpipe is like that and it is stock. Watch what your air intake, make sure with the CAI and the throttle body spacer you are not running to lean.
You're probably going to be disappointed with the AM/FM reception, at least I was. But it sounds like we're in the same boat that it doesn't much matter. Still looks really good though.
Yes reception is poor, but like I said I use Sirius 100% of the time I am driving
It is nice to have that tall boat mast out of the way and not catching of branches and limbs
I do have a small 10"-12" section of flex pipe before the muffler
I looked at it today, definitely have the FOMOCO emblem on the muffler
Going to clean up this used AFE Charge Pipe this week and install it next weekend, looks very easy
Very large diameter.........we will see what happens
Took some part number tag pics of the VVGG code rear springs and the rear two piece shaft
VVGG springs:
Rear driveshaft:
I am pulling the Leer cap off this weekend
Next Friday, the truck bed and tailgate will be sprayed with LineX
Started to remove the cap, bed tie down hardware, and plastic drop in bedliner
I like the thick rubber mat, definitely going to keep it
Removed the four clamps and off came the cap
Definitely did not like the piss poor wiring job the cap has. I am going to run single, 12G hot wire and a short ground to a 3 outlet 12V accessory center, which I will mount on the inside of the cap lip
Looks much different
Deputy Dan
