NEW RIG: 2012 F-150 FX4
Installed the AFE Charge Pipe and JMS PedalMax tonight
Turbo noise is definitely louder and with the control knob on the PedalMax system turned up to 100%, its insane the pedal response........even at 50% its a completely different beast
The PedalMax was a cake install.........and I like that I can pigtail in the BoostMax system once I install it, maybe Monday
The AFE Charge Pipe on the other hand was about 30-40 minutes, and a PITA. I don't think that overall fitment was good, at all. I will see how the truck does over the next week or and see how the JMS systems work together. JMS claims something like 80 RWHP!
http://www.jmschip.com/content/BoostMAX/35L/Instructions_BoostMAX_35L_v1_web.pdf
Stock ring holding the bottom of the stock charge pipe in place
The next piece of the power package will be a porter throttle body, from VMAX........then I will be done with the power goodies
$150 for the TB and $150 core, so basically $150 after the core is returned
http://vmaxmotorsports.com/
Great company and great customer service
Hopefully I can get the JMS Boost Max installed this week, because the Pedal Max is doing GREAT
One of the final power upgrades, the ported throttle body from VMAX
Conflicting info on the stock bore size. Some claim 68MM and some say 70MM
I will measure the stocker when I swap TBs, which should literally take under 30 minutes
Appears to be a tapered port, starting out at 75MM and necking down near the blade
Next, I will install the JMS Boost Max.......and plan to run the optional control knob at 50% for a while (87 octane)
VMAX Throttle Body is installed..........cake swap, under 20 minutes
I have read rumors that the stock TB is 68.......it might be, parts of it
The top/inlet bore is 73.75MM and quickly necks down to 68MM within 3/8" of the top/inlet of the bore
The back end/exit area of the bore is 70MM
I could not get a good, solid measurement of the blade, but it appears to be 68MM
It is interesting that the bore is not just one size, and that it decreases towards the blade and increases as it exits
The VMAX starts off at 75MM and tapers also. The blade is stock and after/behind the blade, the bore is also "stock", measuring again at 70MM
I ran the JMS Boost Max for about 5 days
Definitely had an increase in power, but I felt I also lost 2 mpgs
I unplugged it and will only run the JMS Pedal Max, which I REALLY like the pedal feel with the kit installed
If anyone wants to try the JMS Boost Max (adds upto 6 PSI), let me know $250 shipped
Does anyone know if I will have any problems clearing 35x12.50s with these specific wheels?
BMF DRT
17x8.5
5" backspace
+06
P/N #521-785613550
I believe these are the stock specs:
20" x 8.5"
+44mm offset (6.2 inch backspacing)
I have decided to just keep the Raptor wheels and find some 315/70R17 or 35x12.50R17s
All are similar sizes, but I think the 315s tend to run a tad small compared to a true 35x12.50
I wish there was a 305/75/17
I would also consider a 295/75/17 (34.4x11.6), but I like having a 12.50 for a wider footprint
Pedal Commander came in..........love the size and the adjustable features for each setting
I will get it installed tomorrow and compare it to the JMS system
$250 shipped this the Pedal Commander....nice compact kit and neat mounting pad/bracket
Pedal Commander for the win
Not even comparable to the JMS Pedal Max
The Pedal Commander has so many level of adjustment and blows away the JMS Pedal Max
The JMS uses a kind of strange dial knob, which is pigtailed into the Pedal Max
The Pedal Commander has a nice mount, is very compact and is much nicer..............all for $250
Yes, another spark plug swap and oil change today, to get ready for winter
$31 for synthetic oil/filter and $24 for SP534s
I bought some brackets for $10, so I can mount a "hidden" 30"-32" LED bar behind the grill
NorthCaptiva
