Old Rovers Too Feeble?
The 2F is a reliable engine for sure and has good low end torque as you say. 800 lbs. is a weakness. In fact a big weakness of the FJ40 is that it is very heavy in general for it's size and payload. Easily 500 lbs. heavier than an equivalent Series. As far as an FJ40 being less feeble than other old 4x4's, I keep thinking of the FJ40 on the Top Gear Bolivia episode.
Well explain why diesels have more oil.
The 2F is a diesel? Really? Again, I was unaware of that. I was under the impression that it is, and always has been, a gas motor.
Explain to me why the sky is blue. Why are tomatoes green and then red? If you had to punch Jesus, your Grandma, or your mom in the face, I mean, absolutely HAD TO or they all died, who would you punch in the face?
Explain that one for me please. Oil capacity does not make a motor better. It just doesnt. In fact, more oil can cause you to lose power if the crank has to go through it.
In an off camber situation there is more oil in the pan that can be picked up by the pump.
Sent from my iPhone using Tapatalk 2
It's cute you're trying you're trying to be a ************. I never said it was genius :)
1. You know, you can go back and edit posts instead of creating four one liner posts as you research and come up with answers.
2. Oil does absorb some heat but that is not its primary purpose and all of that is depending upon the internal design of the oil galleys and passages. Heat actually leads to a breakdown in oil.
3. In an off camber situation, if you have a lot of oil, itll hit the crank, become aerated and that can lead to starvation. Baffles and windage trays are far more effective.
Yep your a ************.
1. Who cares?
2. That's why there is 8 quarts :)
3. It's a deep pan and there is an oil cooler
So genius. Explain why heavy duty engines use a lot of oil. Since you're so smart and obviously an engineer.
LukeSkywalker515
