Pelican verses Zarges
Anyone have any experience with the Underwater Kinetics cases? There's a distributor just down the road from me and they have great prices... I'm just curious how they compare to Pelican's...
I am going to go with the interlocking ones from ECS.
I called up Cases2Go earlier about the Zarges, and as much as I like them, they take ten weeks to get them as they are made to order.
Now I have to do some serious measuring this weekend to configure a floor plan for some.
A couple thoughts regarding my experience with Pelican cases. I have two 1550 cases, one for parts and the other for tools as well as a smaller 1450 which has yet to be assigned a duty. The boxes are mostly square so it is only the corners that may present a problem and I am not packing a bunch of square little boxes so it is not much of an issue. I also find that the larger the case the less problem there is with fitting items in due to the rounded corners. I also like how you can lay the Pelicans flat or stand them up on edge which can give you more options for packing them in the truck. Don't get me wrong I have serious Zarges lust but I think the Pelicans are better value. Here is a picture of mine packed in the trailer.
Hello Corey,
Yeah we are in Sweden, but pretty close to germay.
Shipping from Germany is not really that bad. Guessing aroung 45€ for a box to the USA.
Mike
FWIW, I've had both both Pelican and Zarges cases. I prefer the Zarges cases for overland duty. (The Pelicans are now used in the garage for storage – mainly - I should probably sell them.) Don't get me wrong, if i was carrying the cases on the roof and expected I might roll the truck down a hill into a stream, I'd go with the Pelican cases 'cause they seem bulletproof; however, this isn't usually the case (pun intended). For our brand of overland travel, I like the Zarges cases because they are rain tight, sturdy, dust and bug proof, and sized perfectly (14" x 22") for our needs. I have the k470 boxes in three different heights (9”, 12”, and 15) with each serving a different function. Since I’m lazy, I appreciate the fact that they very lightweight (unlike the pelicans) and sized just right so I can get others to move them about. When stacked up and strapped down, they are solid as a rock. The only complaints are: they cost a bomb, are a little noisy ('cause they are aluminum), and are easily dented/scratched (also 'cause they are aluminum). Hmmm, come to think of it, these are the same problems I have with the land rover.
As much as I like the Zarges, the 10 week turnover is a little to much.
I was quoted from a customer service rep that each case would carry a price of $175 each to ship it quicker.
Dear Corey,
These cases are stocked at their Germany warehouse. The standard lead time is 8 - 10 weeks for them to get over here. If you want to have them air freight over here to make the lead time shorter, it is an extra $175.00 per a case.
I think the Lego type ones will work out very well for me.
I like how you can interlock them.
Now if I could find some Zarges in the states here, I might go for it if I could get them in a weeks time.
@ crusader
Want to pack with one of those Peliboxes?
I am still looking for one, for my Camera.
It looks like they have 4 or 5 more of those Pelican 1400 cases in now. Let me know if you want one and I'll pick one up for you--They're $28USD each. The foam is cut out for whatever component was originally in there.
--Mark
I couldnt tell you the first thing about Zarges cases as I haven't used either, but being in the military, I have used both pelican and firestorm cases extensively... Pelican cases are slightly stronger and more crush resistant (more flexible plastic and a little thicker, though not by much) but the latching system, at least on the older ones leaves plenty to desire. I've seen them unlatch from 3ft drops. The Storm Cases I have used however have never come undone in my experience, and we don't tote lightly, especially when loading or egressing vehicles in time critically sensitive situations.
If you plan to use your case as a jackstand (which i've done as well) then go with pelican, as it will hold up to the higher weight... but if you doubt you'll do anything more than sit on the case, have it fall down a steep hill or just float through some rapids, the storm case's latching system is far superior, and the little discount in price always helps, too!
Getting ready to pull the trigger here.
The size I did want (29x20x12) is no longer made, so I think I will go with two of the 29.2" x 25.0" x 12.0" ones.
I emailed the company to get a little more info such as the optional hinges, and to see how long it takes to get them to me.
Hard part will be picking the color :D
Since I have a black interior on the rig, I might go with black cases to keep them stealth looking in there.
when I used to do interior photography I had these large cases that were grey inside ! the reason is black becomes a hole and is easy to loose little things ?
having a light colored interior is really really nice sometimes just a thought :)
Good points Honu, maybe the Earth tone one or the green one might be better.
Dave, I forgot to add the link above, but it is in this thread near the beginning.
ECS
http://www.transitcases.com/catalog/p-38-loadmaster-tm-lm2925-12.aspx#
They make all different types, and they interlock with each other like Legos, pretty cool.
http://www.transitcases.com/online_store.html
The military foot locker one is pretty cool too, but $300 each for the foot high one, plus 33" long is kind of pushing it for me in my rig.
http://www.transitcases.com/catalog/p-94-loadmaster-tm-military-footlocker-lm3321-fl.aspx
I might have to measure again, because I actually like the foot locker design better, plus it has the top two storage boxes.
Measured some more, and I will be able to squeeze in stacked on top of each two of the foot lockers.
Usable interior space according to their other 12" high boxes is around 10.75", the same as my current Action Packers.
So I am pretty sure two of these will work out well.
I will still leave a little room down the passenger side to stash stuff.
These will be stacked up tight against the side of the ARB fridge.
Fridge is a little lower but not much, so it should not affect me seeing out the rear window that much.
I hardly use the rear window to see out of anyways though.
I've got a couple of the ECS transit cases. Do the footlockers also have the lego tops and bottoms? I can't quite tell by the pics...
Are you guys putting these on the roof or in a open bed??? They seem kind of overkill for interior storage. I've seen those military boxs up close. There are latches on all sides that woud be tedious to open very often. Also a lot of extra weight unless you truely need waterproof exterior storage.
Bobbyjr
