RedRunner's 2016 SR5 Build and Adventure Thread
Great start on the build - so many options out there for aftermarket goodies.
That there are, still researching stuff to do to it. I *think* I have the tires figured out. I have a buddy who powder coated Trail Edition wheels bronze, not sure if he will eventually sell those to me or not.
Finally got the "Raptor" Lights wired up. I did it a little differently and didn't tap the fuse by the Riverside kick panel, I tapped the fuse in the engine compartment.
I tapped the "INJ" fuse which is in between the 7.5 and 10 amp fuses
Untitled by redrunner87, on Flickr
I then unbolted this bolt and ran the wire through it and re-did the bolt.
I ran the negative wire to the factory negative cable bolt. Now we have lights
Got half of the switchbacks done. When I installed the rear LED turn signals, they didn't hyper-flash so I never installed resistors. Apparently with the front LED's installed I needed to put resistors front and rear. So it took longer than I thought it would, so only got it half done today.
Driver: Switchback Passenger: Stock
The last parts to finish up Phase 1 of the build. I decided to try Rust-oleum Peel Coat in Graphite instead of Plasti-dip. I guess we will see how it compares. LED Headlights and LED DRL/Highs as well.
255/80 Falken WildPeak AT3W's have been installed. Here are some comparison pictures vs stock size. I am running stock suspension and I do rub a little at full lock and going over bumps.
Stock
255's
Stock
255's
Stock
255's
Stock
255's
OchoSolo
