Supertramp Flagship HT Hard-sided Slide-in Pickup Camper
Galley images.
A two-burner Propane cooktop is standard (a two-burner induction cooktop is optional). Black vent behind the cooktop is a galley-top vent for air circulation through the galley cabinet. It is positioned above the heat exchanger on the back of the fridge. The camper water tank is 24 gallons and the sink has a dedicated 5 gallon gray water tank that is located on the back wall inside the galley. The gray water drain hose passes through the basement and is accessed through the exterior black aluminum door at the rear of the camper.
20230623_082003-jpg.786429
Spacious cutlery drawer. This unit has a bamboo divider added (not included with camper).
Here are some images of the empty drawer on a new Flagship LT.
20230623_082241-jpg.786430
20230623_082246-jpg.786431
The galley face is a molded single-piece and the inset lips around the cabinet drawers and all controls, on the side of the galley, are a nice touch.
The below galley cabinet image shows galley storage as well as the dedicated shower mixer and 10 foot hose/nozzle for exterior showers which is standard on all campers. The shower hose can be run out the rear door or out a window. This eliminates an exterior plumbing penetration that can be problematic in other campers in extreme winter temperatures.
There is an interior shower option that adds a drain to the bottom of the shower pan, a shower-dedicated 5 gallon gray water tank with associated separate gray water drain hose, and a 360 degree shower curtain that attaches to the ceiling.
The driver's side bench is made up of two compartments. The toilet/shower basin and storage cabinet.
A portable toilet is included standard. A "Wrappon Toilet Upgrade" is an option and includes the Wrappon toilet and 12v wiring to supply power. In our Flagship, we sourced our own separating toilet. The 'Trelino M' fits the space well, particularly with a teak shower mat we sourced which boosts the Trelino seat to be even with the top lip of the compartment. The Trelino fits in the compartment facing forward. There are likely other separating toilets that fit well. STC now offers a teak shower mat as an option that is works with the Trelino toilet.
The second bench has an extra deep storage space that goes all the way down into the basement. This space is available as storage space until the 800Ah house battery option is chosen. At that point, two 200Ah Victron batteries are located here with a carpeted panel over the top that becomes a raised floor of the now-shorter storage compartment.
The included fire extinguisher is shown as is the heat duct that passes through, and vents to, the basement, but then also adds a foot heat duct.
The toilet is removed from the basin during a shower. One of four shower curtain hooks can be seen on the ceiling. The shower curtain is cut with a very wide top (plenty of room for arm space and avoiding clinging wet shower curtain). The bottom of the curtain tapers into the shower basin.
The following images I took in a Flagship LT, but they are identical in the Flagship HT.
Another view of the fan which includes light in the surround (activated by black button), remote control, and black-out shade.
One of four molded-in LED interior lights along with another L track shower curtain hook.
This is the lockable door to the rear exterior storage compartment (or shower gray water tank if so optioned).
It hinges downward to stay out of the way while accessing.
The 5 gallon gray water tank, for the optional interior shower, is accessed from outside at the driver's side rear of the camper. If the shower is not optioned, this is a storage space. The sink's gray water tank is located in the back of the galley, but it's drain hose is also located in this area.
The interior floor covering is removable and can be hosed off or otherwise cleaned while outside the camper.
The large basement pull out drawer is inside the camper and so inaccessible and secure when the camper door is closed.
In this particular picture, taken while touring STC, the trim has not yet been applied to the upper edge of the drawer.
In this particular picture, the trim has not yet been applied to the upper edge of the drawer, but one can see how large the drawer is.
Drawer inside measurements are approximately 52"L x 20.75"W x 5"D. In our camper, we fit a three step stool, welcome mat, dust pan and dust broom, etc.
Its great to heat they are offering diesel heat and an induction cooktop. Thanks for all your posts, always great info.
Really liked the HT we views at Overland Expo SoCal but my one complaint was, the seating areas are a little on the low side. It would have been nice if they were about 2" taller.
Seat height can be tough since everyone's legs are different lengths. I find them about right. On a previous camper, our legs dangled from the dinette bench seats which is was incredibly uncomfortable. After sharing that observation, the manufacturer started putting in a raised floors and so sent us the mod which I installed. That made the leg length perfect and created a shoe cubby underneath. Double win. I'm 6' and wife is 5' 10" and we find it comfortable (her legs are longer than mine).
Hard to make them perfect for everyone, though. How tall of a fella are you, @ExpoMike? Just would like to compare. I don't know that anyone has ever asked, but I wonder if they would make taller cushions if someone wanted taller seating height? If not STC, then someone aftermarket. Easy enough to add height (though admittedly not exactly cheap), but can't make it shorter.
Any insight into how the interior heights felt? Both HT and in the taller LT?
Anyone else get a chance to check them out STC at the expo over the weekend?
I'm 5'9" but it seemed a little low and made it a little more difficult to get back up. I guess you might equate it to a standard height toilet versus an ADA height toilet. (IIRC 16" versus 18"). We have one of each in our house and I prefer the higher one. This getting old crap sucks!!! LOL
Here are some better shots of what the Supertramp LT and HT basement drawer look like. These are from our LT. We carry our 3-step stepstool, welcome mat, dust pan and dust broom, etc. in ours. I put a foam mat in the bottom to lessen wear and tear. Note that the camper interior mat has been shortened compared to the other images further up. This eliminates a bit of a trip potential when it was flush out to the very edge.
The 24 gallon water tank and water pump are located under the front bench which keeps center of gravity low and forward. One of the three heat ducts runs into the basement and has openings to blow on the water tank. Winterization is simplified because the entire plumbing system gravity drains. No need to introduce RV Antifreeze. The water pump is located after the water tank and before the drain valve and the rest of the plumbing.
Front bench lid, like the rest of the bench lids, is black aluminum.
Lots of room for storage. The HT that I used is setup similar to our LT in that two storage cubes, with dividers, are utilized.
This unit had the optional 1,500watt Go Power inverter. A 2,000watt Go Power inverter is also an option.
A carpet-covered composite panel sits on top of the water tank making the floor for the under-bench storage.
Removing the panel allows access to the 24 gallon water tank, water pump, hoses and fittings.
The Pentair Shurflow water pump can be seen below, as well as the large water fill tube, small water tank breather tube and the water level sensor on the water tank.
One of the heater vent extensions can be seen below.
The drain valve is in the electronics cabinet. Opening the valve will allow water to gravity feed out of all plumping lines and faucets, but it does not drain the water tank. The water tank can only be drained by running the water pump. This allows the Flagship HT and LT to be winterized using no RV antifreeze.
Matt demonstrates the winterization process that is shared between the Flagship LT and HT.
Picking my HT up this year. We opted for a King mattress bed extension and bunk bed! very excited to see how the ST team can pull it off.
Congrats! Looking forward to see some production models come off the line, out being used, and associated owner reviews and pics!
Yea i was a little hesitant to spend that much on one of the first models but the ST team produces some good quality units so i put a little trust in them.
I will definitely share some photos when i pick it up!
I wouldn't be too concerned about it being a new model. As I mentioned, the roof itself is the same as the LT (dimensions, wiring, lights, fans/vents, etc) except a new mold was created to add the hard walls to the existing roof design. The layout, cabinetry, components, etc., from bed-level/counter-top level downward, matches the LT camper, meaning the Flagship HT is a mature product at birth except for the hardwalls and new interior upper cabinets.
ELShockley
