Taco Chaser on board.
taco chaser
Supporting Sponsor
gearbox said:
Howdy!
What sort of setup is required for that run?
I did it 5 years ago when the taco was still stock and I recieved rocker panel, bed, and bumper damage. To be stress free I would suggest at least a 3" lift , 33" tires, rock sliders. The trail is class 3 to 4. It would be great if you can make it!
taco chaser
Supporting Sponsor
Safaribound said:
I just barely observed pictures of your rig Taco Chaser on Adventure Trailers. ********. Now I want one! Your rig is awesome man! post those pics! (send me your pics if you need me to host em) :)
Anyone wish to buy a loaded 80 so I can build Taco Chaser II? :)
Don't sell the 80 , Land Cruisers are **************. Did you say FZJ? Is that a diesel?:drool: :drool:
Safaribound
Wanna trade? :D
FZJ is still gas. Just the updated engine from the FJ 80's in earlier years. HDJ is da diesel!
taco chaser
Supporting Sponsor
Safaribound said:
Wanna trade? :D
To many busted knuckles and good times in this one , I figure when it's time just bury me in it.
gearbox
Well, the sliders I have are on my living room floor so I'll have to sit this one out.
Once I buy my house and I can get an OME and 32-33" rubber under the truck I'll be on "real" trails.
taco chaser
Supporting Sponsor
atavuss said:
used to run that trail a lot in my CJ7. have not run it in my Taco
this weekend is a good time to try it in a taco, lots of tacos might be there from TTORA on saturday. Here's a few pics from about three years ago, Scotty's stock 40, stock rover,and my rig at weird stage.
taco chaser
Supporting Sponsor
Thats up to you, It can be done carefully stock.
dosxxtaco
Love your rig!!! Makes me want sas.. Was your truck in a few offroad mags? I thougt i seen it in one..:bowdown:
taco chaser
Supporting Sponsor
Yeah it was, but the only artisle I've seen is in the proving grounds of last months CRAWL mag. and the focus is on the bed conversion as it should be. Alot of people think the SAS in just for rock crawling but it's not, my steering is just as tight as it was when stock , the ride to me is just as smooth if not a little bit softer, but the main reason is simplicity and strength on the trail.
tacollie
Glamper
How much lift are you getting. Aside from the money, that is my biggest SAS reservation. More lift than I want.
taco chaser
Supporting Sponsor
I did the original conversion for $2800 and thats gears and everything else. Now it might be even cheaper because when I did it there wasn't any kits or parts made specific for the conversion. The lift can be much lower, I'm running 4" springs on the front and 5" on the rear with 6" shackles all around so you have alot of options plus unfortunately I still have the 2" body lift from when it was lifted IFS. You could use your 2.5 alcans in the rear with a 6" shackle and find another 2.5 spring for the front and run a 4 to 5" shackle up front should level it out and allow up to 35" tires thats just off the top my head with out measureing .
taco chaser
Supporting Sponsor
tacollie said:
That is much better than what I priced out. Maybe I need to do some better research.
What did you come up with price wise? I forgot that total did not include the axle that I found with all it's guts $250. So it's closer to $3000+.
tacollie
Glamper
My current shackles are 6.25 eye to eye. So I would really just level out. I wouldn't gain to much travel up front though, just strength right? When I priced it was a lot more because I priced with a more expensive housing and with coil springs up front. I didn't want to loose drivability. I just think I need to do more research. Leafs up front would be simpler and cheaper. I still need to regear so that is a few more dollars.
DanoWall
