The Wanderers build
today's task was an idler. The problem is I don't have an air pump. They do make an air pump eliminator, but with the large alternator and the H1 design, the pulley is too large... but that doesn't mean I can't use parts from that
first, the hole
so for all of those people doing a 6.5 turbo side-mount turbo on a H1 motor in a Square.... this is how you do that... first you take a mercedes idler pulley then bolt it onto the bracket that you'd use for an air pump eliminator.... time to void the warranty
yeah, I know, millions will be doing this swap...
you can slightly see where the bracket is going
test fit
weld it up - yes, that bracket above became this
then finally, work on the front shock spacers
bracket minus the pulley
love welding chinesium.... not
anyway, get the right belt (that was a story all by itself) tomorrow... then finally that's marked 'done'
finally, starting on bolting the springs in... Canadians, look away
belt on, then I realize I could have routed it another way.... c'est la vie
round 1, in the end I only use the spring
in an effort to completely flummox the Canadians, I replaced the hockey pucks (after I drilled a hole in them)
and now it's correctly suspended
the springs hang the axle, not the shocks
driveshafts are here
and installed
no bluetooth driveshaft here
now for the fun. the 86 doesn't have a removeable trans cover... it will when I'm done
so for unknown reasons, GM covered the floor with a plastic cover... which trapped moisture... yay, more rust
and the floor.... it has a story, and I'm sure it's good, but it's puzzling me... such as this crack
we've talked about this seat hole
and this random rust
this rust we knew about
however that hole? no clue
it was covered by the plastic... it looks like someone got after it with a pick... but there's no hole in the plastic cover...
there will be many patches... but for now, remove cover so I can build the shifter for the t-case (yep, method to the madness)
grinding and welding is going to happen inside, so time to clear it out
eww
I really wish I knew the story of this rig... it has some interesting other stuff, like the entire area behind the seats is covered in tar.... to the point it filled the seat anchors
back the spark generation - so here's another puzzler... the center hump is welded down - that was a 2wd only thing... and the vin is right on the cowl...
and even this has some interesting bumps in it
free tools
and more rust... but not terrible.... some needs patching but as I said before, there is no rhythm or reason to it - for example, the fill cover... is utterly rusted out but the floor is fine... why there? there is no way for anything to pool at that point but the lower portion of the cover is gone....
anyway, more tomorrow.
the hole in the fuel filler... I'm guessing there are RUSes in Idaho?
so part of tonight was removing this
removed
next problem, notice the edge? ah well, lots of little fixes
cover, however, was removed
all of this for that bracket.... I'm still on mechanical, in this case, transfer case engagement
yep, a lot of little rust spots but that's not today's problem - I'm going to make this drive before I get to bodywork
big plans, small steps
plan was install the fuel system
not a pump, a sensor....
plan B - fuel pump from when the Corvette was carburated
rather then wait for a part to arrive, I made an adapter for the fuel pump
cut (void warranty)
and welded
installed
problem is it requires one more connector... smuck
finish up shifter... I'm not sure how they planned on getting the nut on this - so I welded it on... problem solved
sway bars... the aftermarket does have options - but all of them are $500 or more. This is $200
and takes a chance
steering is hard left - clears
close, for certain, but not will never hit
plenty of room on the passenger side as well
comes with stands that you can use or simply bolt it in place of the old system
what is this sway bar that works for a cross-steer swapped K5 Blazer? a Classic Performance Parts (CCP) sway bar for a 2wd lowered Chevrolet truck... the only thing missing is how to attach it to the axle
first, the most important task... get these mud flaps OFF my Blazer - granted, fender flares are coming but still... time for them to go
then finally finish the t-case with the correct motor mount (from a Corvette)
only thing I had to do was add more holes to the frame to mount the cross member
I hate drilling holes over my head but I got the full monte of it today... it was only 99 degrees in the shop
however, this works even better
I did have the clearance the bracket so the steering arm didn't hit it
but clear it does. I'll buy some bar clamps to prevent the sway bar from walking
anyway, thanks for watching
So I'm kind of in a holding pattern waiting for parts, not just that but it's been really warm and there's been a lot of drama in the background.... but still, progress was made
tabs for the sway bar
Today's update... flex, finish sway bars, install cross over pipe and fix the resulting problem with the oil lines
to remind, round 1 of the exhaust - using the 6.2 exhaust manifold
problems are it's smaller, and it makes a circuitous route to the passenger side
problem was I didn't have a useable 6.5 manifold.... thankfully, they're really really cheap for new ones
compared to the 6.2
new manifold in place but now it interferes with the oil coolers
thankfully, one fit back and the other just took a bit of trimming and some fittings... and finished
a bit of DEI wrap and send it
crossover in place
sway bars... needed adjustment
time to flex
it's not my FJ40 but it's good enough
basically any corner can be at least 3' off the ground (and I'm sure I could flex it a lot more but this was to see what I needed to clearance
everything clears (not by a lot but clears)
one thing I will change, that e-brake cable is going above the axle
anyway, that's it for now... next step is test the fuel system for leaks (and it was leaking when I had the rear up on the forklift from the front of the motor); then get the intake, install the turbo and start running exhaust... I may try to make noise with it after checking for leaks....
2eleven
