The Wanderers build
it's amazing to me how easy it is to fill such a large space - and then have very little space for the exhaust
thankfully, oval pipe to the rescue
still waiting for Chad's article* about oval pipe...thankfully, since it hasn't been written, this should work just fine.
but even the magical oval pipe can't solve this one
these should keep the sway bar links out of the springs
*highlight of this backstory - on a forum which shall remain unnamed, I got into an argument where Chad told me he would write a HRM article proving my assertion that oval pipe would make a negative difference to flow..... been nearly 10 years and still waiting for that article... and I probably would let it go but this is the same person who proclaimed it was okay to run over bicyclists....
In other news, beside Corvette stuff, I worked on the Blazer
first tape on the clamp to see if it will fit through the hole..
nope.. round 20
more pictures tonight, but I'm going to notch the box... didn't want to but beside getting this through, I need to wrap this... anyway, more, tonight
when I was building v8 Blazers, this was a common tactic to make things fit
believe it or not, the underside was the hardest part
but I got it
time for childlike drawings
hopefully that makes sense now
also started on the wiring... this case, fuel pump
and I have 'helpers'
more tonight
piece epoxied in place
I can't believe it, but I have to since I can see it... all my slathering actually sealed the hole
time to finish the welds
ready for wrap
then put the studs in place on the offset
turbo back in place
close but it is going to require a bit of hammer work
key here is I can finally bleed the injectors then make some noise.... there were open oil lines to the turbo....
not much to show tonight... this now fits
battery safely balanced on top of the core support
after a fill of the coolant system
I'm bleeding the back first - still not getting fuel out of the back but it'll work... thankfully there are no electronics to defeat
tomorrow, crossing fingers, there should be glorious detroit diesel noise
got the injectors bled
then fought a bit with the glow plug controller... it was missing a ground (which is really a paradox on this thing)
of course, then I learned something... you remember how they used to embed a nut in the battery terminal... apparently some bean counter thought that was dumb
used the other battery and carried on (but tomorrow, I'm going to Costco with both and replacing them)
Then I got it fired and this happened
fast oil change
literally blew the line off... thankfully I noticed very quickly
fairly quick fix, I did what I did with the other line and adapted up
Would it be easier to leave the fenders off for a bit more time.... probably but more likely probably not
for example, routing lines is paramount now
Inner fender the outer fender....
maybe more importantly is finding that I need to do a bit of Neanderthal on the core support the bottom is about 1/2" off - and nothing is lining up
however, and maybe more importantly, the batteries now have boxes to ride in
and I can start considering airboxes
time to start putting gauges in.... of course, the downside is I need to figure out my color scheme on the inside. Right now the pillars are white (which matches nothing else on the truck)....
something to keep the crap out... annoying that I don't have enough 2 1/2 silicone tube for this now
anyway, weekend is here, time to relax
seats...
not level
as I worked on other stuff today,
I've had these half doors primered since I got this thing on the road 6 years ago.... today they got painted
Thanks Don!, you rock
didn't do a lot here but I need to either find seat brackets or commit to buying something else..
2eleven
