TheGillz Explo Off-Road Trailer via Geotracker90 Build!
GeoTracker90
Update 7-12-08 Part 2
After the dimple dies arrived I decided that I needed to test them out. Oops, I have a 1" hole saw and a 1-1/4" hole saw and a 1-5/8" hole saw, but not the correct 1-1/2". Never the less I decided to do a test piece on a scrap using the 1-5/8" hole saw.
Murphy strikes! I loaded my 1/2" drill with the hole saw and arbor and begin the cut when the drill makes an un expected twist. That's not right. It turns out that the shank of the arbor, which had been turned down in a lathe to fit in a 3/8" drill, finally gave up the ghost. I made a temporary fix by inserting a chunk of 1/4" drill rod into the hollow cavity of the arbor shank. It ended up having way too much run out but worked for the test piece. I picked up a new arbor and a section of 2" square tube for the trailer tongue before going out to the work shop Saturday morning.
The first picture shows a completed dimple and the dimple dies. The second picture shows how the two dies are used to sandwich the sheet in order to form the dimple.
The center sheet has 14 holes drilled in it in preparation for the dimple dies and the press. The flat sheet with the holes in it really is not all that impressive. After a trip to the press and 14 turns with the dimple dies the sheet takes on a whole new look. This is really going to look cool.
Just a close up of a couple of the dimples.
I've heard that once you have a set of dimple dies they get addictive. I'd have to say that I think they are right. I was able to get five out of the six panels cut, bent, drilled, and dimpled last night. I would have completed that last little panel but my sheet metal shear had broken down and I had used every scrap of a cut off disc that I could find in the shop just to get done what I did. Just to save you the bother of counting each of the dimples in the shhets I let you know that there are 38 of them so far.
I also completed a lot more of the finish welding on the main storage box as well as welding the Lock-n-Roll hitch piece to the 2" square tube (1/4" wall thickness) for the tongue of the trailer. I din't bother taking pictures of that stuff, it just seemed too boring by comparison.
Mike
ZR2nit
Mike,
Great job so far. The dimple died holes look great. I'm sure it will lighten up that front end too.
TheGillz
That is a really cool new toy you got there! I like it alot. I am wiped from this weekend, but lets go with 2" rather than the 1.5" on the roof rack, and maybe just a half inch in on the front and back from the edges. How much usable space would that give us on the flat top?
For the AT guys or anyone else familiar with the RTT's, if I plan on using a 3 cross bar mounting style, how far apart should the outside ones be? Our plan is to get the Large mombasa unless we find a good deal on an Eezi 2200 or Overland Large....
Thanks. Looking awesome. We sure could have used it this weekend, and it will definately be a indespensible part of our outfitting, can't wait!
TheGillz
I just re-read my post. Let me clarify.
An additional half inch in from the ends than what is shown. It looks like about 2 inches...so maybe 2.5.
So unless I get diff feedback on the rack issues. 2 inches high, and 2.5 from the ends...
GeoTracker90
lx450landcruiser said:
so am i correct to assume these dimple dies are used with a shop press?
looks fantastic
Yes, they typically are used in a hydraulic press, but if the piece of metal is too large it is possible to use a big @$$ bolt to draw the two pieces of the die together. Some people have built a stand alone press like the one in the following picture but have reported problems with deflection. I think that with the proper engineering one of a similar design could be built to withstand the pressure.
I must say dimple dies kick but!
Mike
GeoTracker90
Update 7-16-08
I went out to the shop tonight and intended to get the roof rails completed but instead I worked on...
Getting closer all the time.
Mike
TheGillz
Rezarf <>< said:
Personally, I don't think the duct tape tailgate latch will last long off road :D ;)
Looking great! Keep it up!
WHAT? Duct tape is the engineering cure all! Plus I carry a really big roll! :smilies27 :oops:
GeoTracker90
That's funny! Now that I look at it the picture does look like it has duct tape. It is actually the spanner wrench for my angle grinder slipped into the uncapped end of the 1" square tubing.
Mike
jordanP13
