OldSven
The coils are in and finally done. After 3 different setups with spacers and without I finally nailed it. This setup works great for a Tacoma with a heavy winch bumper. The Tundra struts are able to hold the weight with a very comfortable ride, but are just alittle to short to level out the front with a 3" lift kit in the rear. I tried running my old ToyTec spacers in with the coils but unless you have 3-4 winches up front this ride will kill you. So I removed the spacers and put them back to stock. Came across a spacer lift that I had looked at once before but had heard mixed comments on the product. Well without going to coilovers this was the last option. Installed the spacers on top of the strut and installed back on the truck and it was back up to height and kept the stock ride quality of the progressive rate spring. here is the truck with just the Tundra struts and then with the spacer added.
Instructions: -Tundra TRD (4x2 or 4x4) struts.
-Remove swaybar completely
-Switch Tacoma top plate over to Tundra pack.
-Compress back together
-Trim Tundra rubber isolator around top plate
-A 2" lift spacer from www.extremetrucktoys.com
-Ready to install.
The total price for me was about $300, I had access to a spring compressor through work so that part was free. And after removing the struts so many times I can do it with out even removing the wheels, hopefully this setup will allow you to only have to remove them once cause it gets old after 3 or 4 times...
-Ready to install.
![P7140003.jpg](http://i49.photobucket.com/albums/f294/OldSven/P7140003.jpg)
![P7140004.jpg](http://i49.photobucket.com/albums/f294/OldSven/P7140004.jpg)
![cd_1.jpg](http://i49.photobucket.com/albums/f294/OldSven/cd_1.jpg)
![P7140005.jpg](http://i49.photobucket.com/albums/f294/OldSven/P7140005.jpg)
![P7140006.jpg](http://i49.photobucket.com/albums/f294/OldSven/P7140006.jpg)
![P7150011.jpg](http://i49.photobucket.com/albums/f294/OldSven/P7150011.jpg)
![P7150012.jpg](http://i49.photobucket.com/albums/f294/OldSven/P7150012.jpg)
