UJOR Build Thread
Ok here are the details on the revised coil setup! We're only selling as a complete kit, everything is included but the application specific parts like transmission x-member, shifter, fuel tank kit, etc. If you already own this conversion we'll have a special price for the upgrades if you choose to install them. (I would) New radius arms are on my list of things to do, we'll make them and go into production with the next coil swap done here. Axles and t-cases are also available. Here's what you get for the kit prices below (I'll post a complete pic soon)
Radius arm mounts
Radius arms
Upper trac bar mount
Lower trac bar mount (weld on)
Sway Bar w/links
Coil springs
Coil spring & shock lower mount
Complete hardware kit
Crossover steering knuckle/steering arm
Trac bar with 7/8 heim joints
Engine x-member brace
Drag link with ends & clamps
Tie rod sleeve/bolt
Fox Steering Stabilizer
Steel braided brake lines
Fox 2.0 shocks front/rear
Pricing:
4" kit with rear blocks and add a leaves: $4495.00
4" kit with rear leaves: $4995.00
6" kit (also w/rear leaves): $4995.00
I have knuckles being machined right now and everything else on the shelf or being made as I type so we'll be ready to ship in ~ 2 weeks. Let me know if you ave any questions!
Chris...
Is the coil kit still mainly bolt on or is there welding involved?
There is welding required now. Lower trac bar mount and I'm going to recommend welding the upper mount too.
Just did a 2hr final test drive of this van and its really nice, super happy with the results. No stabilizer, tracks and steers great.
Was this van a 4" or 6" kit? How does it compare to your comparable leaf kit? Sorry to reopen the debate of leaf v. coil, but now that you've done this upgrade to the coil I wonder if it changes the analysis. Thanks
This van has the heavy 4" springs in the front since its a SMB. The leaf kit is still my favorite for backroad driving and handling but these changes to the coil kit as huge and I'm much more confident after the changes. Some rigs are better off with coils, some with leaves. Lift height, year, engine, weight & intended use are all considered when I make recommendations for either.
Stage2 Dana 60, True Trac, 4.10s, Spyntec 8 on 6.5 hub conversion, SSBCs, ready to go under an RV in NY, DIY conversion
The revised coil van has made it back home, here's what he had to say:
“Ended up running straight through yesterday with a detour up Shenandoah np. Totally different van. Hit 75 for the first time (2 or 4wd) which I still don't recommend,but not because of the twitchy steering anymore��
No bump steer, and I hit some real nasty ones! Wash board, uneven lanes, the nasty dips before over passes, all with no anxiety. Well less anxiety with each hit. Thanks again. I'll keep you posted.”
2eleven
