This was from another thread kinda like this....
I've often contemplated building a vehicle from scratch, not starting with something stock, but starting with a blank sheet of paper. Has anyone else thought about doing something like this?
Here was my starting list from another thread........
-aluminum 4-liter mechanically injected turbocharged intercooled diesel
-manual and automatic transmission option
-6-spd manual or 6-spd automatic with tiptronic style shifting option
-3:1 geared transfer case that is synchronised high to low range
-The ability to have rear wheel drive, all wheel drive, center diff locked 4high and lo, front wheel drive would be nice for front digs, but that can de done with an open center diff.
-divorce mounted transfer case with identical front and rear drivelines
-great quality axles that are rebuildable and serviceable (bearings, drop out 3rds, brakes )
-locking differentials front and rear that can engage under power, can lock with zero wheel movement, and unlock without wheel movement
-A limited slip in the unlocked position would be nice too.
-full floating rear axle
-BIG huge brakes with no abs
-real wheel bearings and the ability to have hubs on all 4 wheels
- 35-37" tires stock
-No taller than 72-78" at ride height
-good amount of uptravel....6-7" would be nice
-upgradeable coilover style suspension 12-14" coilovers
-ability to bolt in hydro-pnematic bumpstops at all 4 corners
-limiting straps at all 4 corners.
-Have both axle center sections offset to one side
-high pinion axles that get the driveshafts way up and out of the way
-simple long radius arm style control arms that are identical on all 4 corners
-good belly clearance, something around 20"
-flat and smooth belly with replaceable aluminum skidplate
-sunken front winch mount that doesn't effect approach angle
-ability to mount any 4.5x10 pattern winch feet forward including an 8274
-LARGE overkill cooling system, big huge radiator and fan system
-ability to carry 2 full size spare tires
-great approach and departure angles
-good HID headlights
-LARGE fuel tank, just one for simplicity, but centered in the car with great clearance
-simple replaceable body panels that could be made at home if wanted
-spaceframe construction to keep it light and safe
-aluminium body panel 'skins' that can be changed fairly easily
-good over-hood visibility
-large cargo area that has the ability to swallow something long like skis or boards
-cargo area doubles as a flat sleeping area
-110" wheelbase on 37" tires could be perfect if kept under 78" tall
-80" overall width to the outside of the tires.
-Have a plastic 3" flare on each tire that is easy to replace and universal on all 4 corners
-45 degree steering capability on the front axle
-steering box strong enough to turn the tires aired down
-double beadlock hutchinson 2pc wheels 17x8.5, 8-lug, 4.5" BS, forged aluminium
-Dana 60 sized front axle u-joints, 35 spline axles throughout, stronger alloy axles
-I only want a 2 seater but I know a 4 seater would be better?
-flat easy to replace wind-shield
-rear view backup camera with good side mirrors
-as much storage space as possible, use all nooks and crannies
-factory engine driven on-board compressed air system
-160 amp or better alternator
-simple single group 31 battery
-straight track-bars front and rear that are the same part, with rebuild-able ends
-rebuild-able/replaceable joints on all the suspension parts
-fresh air ducting coming from the windscreen pressure zone
-sliding side windows like a series land rover
-large 1+ gallon windscreen washer reservoir
-heated side mirrors, seats, windscreen, and wipers as a winter package
-I'll 2nd the vote for the room for chains on the 37s....or 40" tires
Thread.
http://www.expeditionportal.com/forum/showthread.php?t=40075
Pics of the concept I came up with and some scale info.
ttt = to the top
Thanks for the insight Jesus. I have been watching your site for a few years now. I float around on Pirate and a few others. I like your style of modifications....
I have been a little busy on the idea. Ok...more than a little busy. I have been designing a chassis that could be laser cut on a 6-axis tube machine like a Mazak Fabrigear. The design is ending up like a cross between a Foers Ibex, a Defender 90, with a little QT/Bowler Wildcat mixed in.....but with room for 37" tires and a low overall height. These pics are of a quick 3d model that was to scale. I've changed a bit to make it look better, and I am still tweaking it for chassis clearance vs tire clearance vs appearance.
Its a bit boxy and is suppose to be, that way all the body panels are very easy to make out of flat material with only a bend or two and flanges. The fender flares are all a common, and can be cut from a single flare mold.
Specs are....
110" wheelbase
37" tires
80" overall width
70" wide body with 5" flares
20+ inches belly clearance
Great approach and departure angles
The chassis is designed to be built without a single 'bend' out of 1.5" square tubing mainly, with some other sizes and thickness's mixed in.
