My *slow going* M416 camping trailer build.
jeepfreak81
Thanks guys! I could not have done it without my buddy.
It is finished for now, ready for our trip other than labeling the switches which I will do tomorrow.
Foam on the uprights @ camp to keep grease at bay.
Lift Mech for now
Battery box, there is a float charger mounted on the front wall of the box that you cannot see in the pic.
Rear reverse/spot lamps mounted. They also can be turned on using one of the toggle switches on the box when unhooked from the truck.
Extinguisher mounted
Hand brake moved
New linkage made, just need to go buy a 5/16 nut. I had a die, but no nut.
Light test
Edit:
Switches that are hooked up are labeled. I have plans for the other two eventually, the flash kind of washed out the words though.
jeepfreak81
Generator mounted and locked up, keep the honest guy honest anyway.
My dad was being a smart *** and said it was missing something, so I set up the last two switches just for him
I don't know if I will get the proper Flux Dispersal though between the trailer and H3, especially without the stainless steel exterior.
:smiley_drive::sombrero:
jeepfreak81
Was loading for our trip and saw the 33's were going to rub badly, so ran it to the tire shop for some new rubber. I didn't even have the cooler in and saw signs of an issue. Really didn't want to do it, but with 2000 miles ahead of us and a toddler with us I wasn't risking it. Put us behind and didn't make it to where we planned so we are in a state park tonight. We got in late and got to find out exactly how handy those back up spot lamps are when disconnected from the truck. The cooler lights stuck to the inside of the lid are perfect too. Pics to come later!
Sent from my ADR6400L using Tapatalk 2
jeepfreak81
Can't remember, did you do a springover? Only way I could get my 33's to fit.
No I didn't because of I do it wouldn't ride even close to level behind our stock H3. I would spring over it if it was behind my big jeep
jeepfreak81
Hector just went in and out, in and out... he loved it.
I can sniff them out... these have been in this spot well over 10 years. I first saw them around 2001.
By the light of the trailer lid
jeepfreak81
Thanks!
More...
I left my GoPro in time lapse mode during the thunderstorm, the next three shots are the only 3 out of 1000+ that caught anything.
Kitch-iti-kipi
PNWav
