86 Suburban, warwgn's build.
warwgn
Got the black down, tomorrow I will tape it off for the charcoal.
warwgn
Started to tape it off and changed my mind again, had to do charcoal first bit think I have it figured out how to do it now!
warwgn
Almost done, still need to wetsand and hit it with clear but this is it, should have the gages in and mounte in tue truck this weekend.
warwgn
Yes it is true, I warned you I was OCD!!!
Paint was not doing what I wanted so maybe 3rd time is a charm!
bloodyWEST
OMG, this thing better look like a Ferrari when your done, I've never seen such attention to detail on a 30 year old chunk of American steel.
i would have wiped it down with solvent, then put one coat of rattle can on it :)
can wait to see it together thought.
warwgn
Ok I got it all sanded back down and primed, then didnt like it still so went back and did some more bondo glass and got it primed again and seems fine.
I changed the paint scheme just a little, I went with 1/8" stripe vs 1/4" and did not seperate the A/C controls from the vent.
Takin off the tape.
And stuck one gage in just to get a good look.
Now when I get home today it should be well cured and dry so just need to lightly hit it with some 800 then 1500 grit and shoot the clear. Should have it mounted tomorrow maybe?
warwgn
Might be the tempature, the kimd of clear, or tje way I am spraying the metalic?? My clear is laquer so gonna get some enamel, then gonna try going very light coats on the metalic, its supposed to be in the 70's the next few days so that might help. Also gonna wait at least 3 days of dry time before I spray the clear......or should I spray the clear right away before it dries good??
dblosch
CLOSE.......But no cigar!!!!!
Man- You are killing me!
We had a '91 in almost that exact metallic smoke grey color, and later an '88 in a metallic rootbeer brown (originally two-tone brown and tan)...
I am so ready to see this thing put back together!
warwgn
Well on the good side I got shafted today!!
And yes I sent him my own paint so it would be color matched!!
And yes the plan is to paint metalic black with a metalic charcol grey stripe and pin stripes.
sunnyaz
