Step
Lots of odd jobs today, most not picture worthy. I fiberglassed the sides of the accordion top sides, worked on cabinet doors, installed the external 110V hook-up and did some trim work. I am using the old trim were I can, as you see in the pictures below.
I also started boxing in the step into the van. This is a great illustration of how easy it is to work with wood and epoxy. I screwed in place the pieces that I felt needed to be snug with their attachment points. I then fit the other pieces as best I can, but with no need for a perfect fit. You can see the wedges I used to make a tight fit without regard to the seam between the pieces of wood, when I add a fillet of epoxy they will join fitting perfectly to the step. Once the epoxy hardens I will pull out the step, sand, finish and put back in place with nice trim and more Allure flooring.
I also epoxied some brackets I will use to close off the back above the windows.
