Kitchen Kit/Chuck Box
gavinodunne
Love this idea is there any chance you could forward on the cad drawings would love to build one myself.
Wow!
VERY nice guys! I love the metal and wood construction.
This weekend my neighbor helped me cut my chuckbox on his CNC machine. I prepped all the panel drawings, then he loaded the CAD file into his CNC software to set various parameters, then the machine did the rest. Cuts, dados, skeletonized panels for weight reduction, the works. We did a test fit with a junky scrap panel (not shown) and everything came out pretty much perfect but for some minor tweaks. Built out of exterior rated ACX 1/2" fir plywood (sourced from local lumber yard so it's higher quality than HD or Lowes material).
6.5 lb. of weight were shaved out of the chuckbox by doing the skeletonizing and cutting panels back where I could. Total weight should be ~28 lb. empty.
My friend who runs the cabinet shop wanted one and another friend of mine wanted one, too. So we just slapped another sheet of plywood on the CNC machine ran the cut program again. It was like hitting the copy button on a photocopier. LOL. It was simply mesmerizing to watch the machine cut out the pieces. We also cut out the pieces for my friend's cargo deck system for his Wrangler, too.
Anyways, a bunch of work ahead for finishing and such but this is a start.
The machine cutting out the skeletonized holes for weight
reduction and the dados for the adjustable shelves.
The sheet all cut out with all the pieces needed for the chuckbox.
L to R: The outter box pieces, the internal shelves, the
chuck box pieces and interior partition, and the door pieces.
In the back ground is a mock-up we did a test cut on. That's
what the base will look like when it's put together.
The whole chuck box, all wrapped up to go home.​
Willman
What a great thread! 48 pages of great information....I need to set it up in this department. I have been using a rubbermaid for the past years...I guess sample is easy....
Honu
lost on the mainland
had not seen one like that before ? always see the pull out yellow drawer ones with a weird tip out at a angle below ? might have to go check out lowes this week
I did kinda want something like that for all the camp extras we seem to have and want access to but be able to unpack and pack quickly
Saw this on Pinterest and Thought it might give some folks some ideas. Seems like a great idea and available in any Home Depot or Lowe's
Splash
Someone had had the same idea I had. Top part is cooking items, middle for utensils, condiments etc to put on table and bottom holds dishes.
xander69
